ECX Boost won't reverse or go forward!!!! PLEASE HELP!!
Okay so I crashed it into the curb on the front and then reversed and hit it in the back and it wouldn't move....the lights will work on the ESC and the steering is fine but its just the moving part that is messed up....please help me out, thank you guys so much
RE: ECX Boost won't reverse or go forward!!!! PLEASE HELP!!
What do you mean by "signs"? Like no it won't work obviously....like if you roll it forward or backwards, the things inside(I think the brushes?) are moving around in a circle like they are supposed to but it just won't move or anything....somehow its screwed up. Do you think I need a new motor?
So you drove it into a curb, reversed, and hit something else? Nice drivin' there, Tex! <chuckle> Well, what I meant was, Does the motor still function? If you took the motor out of the car, still connected to the ESC, turned on the power and gave the transmitter some throttle finger, does the motor spin?
