Carbon Fiber
RE: Carbon Fiber
do you have any body shops around? go find one of them or an automotive store. they should carry the resin and everthing you need. if you have to, ask for scraps. if you cant find carbon fibre anywhere then go to your home improvement store and look for fibre glass and resin.
RE: Carbon Fiber
Thansk - There should be places on the net to order carbon fiber sheets to cut custom parts. You hear of people doing it all the time, I just want links to where these sheets can be ordered from???
FL
RE: Carbon Fiber
I was gonna reply earlier but the link was on my other computer, this is the best place to get carbon rods, plates, ect..
http://www.arts-hobby.com/store/item...pid=1&pcatid=0
RE: Carbon Fiber
Grif 0 you think those are strong enough for what i am doing? How think do you think it would need to be, and how thick you think some custom battery bar straps for a TC3 would need to be?
RE: Carbon Fiber
defiantly do 3mm on the chassis. my IRS cf chassis on my tc3 is 3mm, the chassis i have been designing was out of like 2.3mm and with the tc3 setup, it tends to droop and/or flex to much. as for the battery straps, some like 2mm would be fine. just curious, but do you plan o Cad'ing your new chassis or just sorda doit as you go?
FL
RE: Carbon Fiber
Studysession, make sure you find out what type of carbon fiber it is. Do not get "Wet" carbon for an R/C. Try to find "dry" carbon. Some reasons behind this is that "dry" carbon is made with the epoxy in the fibers already (it stays refrigerated untill it is "baked"). Making it stiffer, stronger, and lighter then "wet". "Wet" carbon is just a carbon fiber sheet that has had epoxy poured on it which makes it heavier and a little less stiff then the "dry".
Gecko
Gecko
RE: Carbon Fiber
Gecko - good info, thanks!
Sleepy - I assume you mean the design? I usually hand draw everything. May sound weird, but I will do everything with a cheap plastic sheet I have first, line it up and see how it fits then redo everything with carbon fiber once I have what I want..
Banned
RE: Carbon Fiber
No, making a prototype out of less expensive materials doesn't seem weird. That's how designs SHOULD be done. Hey, if you want to scan your sketch and send it to me, I'll be happy to CAD it for you. That's what I do for a living. Make sure you dimension it completely. I can also help you refine the design structurally if you want. Drop me a pm if yer interested.
RE: Carbon Fiber
Thanks - RIght now I am in very early stage. Still trying to deside on which 1/10 scale pan car. Been surfing and comparing - seems like Associates rules in this class of cars.
RE: Carbon Fiber
oh there is NO doubt that its good to prototype out of cheap material. I am about to do that myself as soon as 1 more part comes in so i can model it.
Then i am gonna start modelling my stadium truck design that will spank the "speedmonkey"
haha, couldnt resist. Hey speed, you use solidworks right? ever installed and used the "print 3d" option?
RE: Carbon Fiber
I was actually just looking for a place to buy sheets of graphite or carbon fiber and was having no luck, so this forum had the perfect links!
I want to cut a chassis plate for one of my drag cars. What do you guys suggest when cutting the plate? Also, how would I be able to cut the battery slots, extra without cutting through the whole plate, know what I mean? Which tools would I need, or is there a place I could sent it out too, along with the design and have them cut it?
Thanks!
Thanks!
RE: Carbon Fiber
dremel will defiantly work, but will also take some extra effort to make it look good. Once i finish my design, i know a guy that should be able to laser cut my cf chassis. If anyone is intrested, if you can give me an idea of what you want i can see if he can quote it.
