What are the differences between these two brushless?
Just wondering what are the differences between these two novak brushless setup:-
1)SS5800
http://www2.towerhobbies.com/cgi-bin...?&I=LXDDD7&P=0
2)SS4300
Do any of you guys know?
1)SS5800
2)SS4300
IL
RE: What are the differences between these two brushless?
ss4300 is a lower rpm motor designed to replace stock brushed motors. It is pretty much useless though because you can limit the rpm on the bigger 5800 to the equivalent power output. FYI, the numeric naming of the these motors is based on the rpm per volt- so a six cell 7.2 volt will allow 41760 rpm and the 4300 will allow 30960. The stock setting on the 5800 gives out 29000 rpm... I have the 5800 and love it! Just make sure to follow their guidelines on pinion spur usage- it can overheat and shut down...
You will get faster and better performance out of the 5800 - I have one. It is a good setup for beginners to brushless.
