Gearing my Novak Brushless??
Love the Novak System in my TC3. Need some help though. I am using the 72 pinion that came with the kit and a 24 spur I pulled of of RTR Losi. I have had some problems. gearing won't mesh for long and motor just spins. Any recommendations? What are some of the better gears I can buy and how should I gear my TC3.
Dmoress
Dmoress
Banned
CA
RE: Gearing my Novak Brushless??
well first of all the spur is the bigger gear and the pinion is what goes on the motor plus if they are not messing right its prolly bc of the losi pinion being a different pitch associated runs 48pitch pinions so make sure its that then idunno how to gear tc3's but associateds website gots setup sheets on it u can go by they tell u everthing on how to set it up like the ros cars
CT
ORIGINAL: Dmoress
Dmoress
Dmoress
If you want to make the investment it is so worth it. It is fast. Easy to install. If you are not racing and you are just bashing or racing with friends it's great.
