!!!PROLINE MASHERS 2000 VS. IMEX TRUCK PULLER TIRES!!!
#101
Banned
ON, CANADA
RE: !!!PROLINE MASHERS 2000 VS. IMEX TRUCK PULLER TIRES!!!
you're killin' me... slowly... painfully...
#102
MO
LOL!
think about it - you have a steel axle (and a fairly small diameter one at that) rutting out a plastic wheel that carries 1/4 of the weight of your truck and spins quite a few rpm while the truck is running. Add to that the force of a landing from some of the jumps you do...
I think you'll see before long that you're just gonna destroy the two wheels that are on the front.
#103
Banned
VA
He's right, but I like those kind of hop up's. You destroy 50 other things, but you get those damn wheels on there! (I have many of those)
-Wes
-Wes
#104
Banned
ON, CANADA
soooo?....will my wheels still work in like 3 weeks!!!!.... or should i new front rims and tires?[X(]
#105
MO
I don't have a crystal ball, man!
...but I don't need one to tell you that you're trashing a perfectly good set of rear wheels!
#106
MO
Not to mention, that even if you end up reaming the mounting hole a little bit, they won't mount up straight on the rear anymore either! wobble wobble wobble...
#107
Banned
ON, CANADA
#108
Banned
VA
The worst part is your going to have to unglue the tires on them when you get a good set of front rims.
-Wes
-Wes
#110
Banned
ON, CANADA
hey! gonna bring back an old thred!... i was jus wonderin' can u run soft tires with out foam inserts?... like "45" u have ur pede with them pullers with no foam inserts!... like do they work good with no foam inserts? like do they try 2 rip off the rims?
#111
AZ
hey im gtting imex pullers tonight and then berings then a p-94 13x3 and i should be set and i also need shoks because when i lift the truck off the ground the tires stay in the same position but then i can pull them down a bit and wheni set the truck back down they get a little bit smaller but with that 13x3 how fast will my truck go i think that SAEWOT hs won do u if so will you tell me its performance and how often i will have to change the brushes and do com cutes luky for me i know the guy at the hobby shop so i get free com cuts and what are some recamendationds on spring i want stiff wons
any replies would be great
p.s i am new to the forums and man i just love em i wouldent know half the stuff abought rc i know now if i didnt have the forums and i have a rustler
-brandon
-brandon
#112
Banned
ON, CANADA
i donno with a 13x3 on 6cells!...in a pede im thinkin' 35 mph!.... geared correctly!
#113
My Feedback: (16)
CA
ORIGINAL: aliens8mycow
My 8 ball says "Ask again". So I did...about 20 times!
#114
MO
That brings up a great question... saewot - are you still destroying those rear wheels on the front of your evader?
