OFFICAL PEDE THREAD
#6576
RE: OFFICAL PEDE THREAD
I have an Electric Stampede with a Mamba Max in it.
When I Spin one back wheel the other stays almost still. Shouldn't it be turning the other way? However when I hold the spur gear while doing this the opposite wheel will turn back like im pretty sure its supposed 2.
When I spin the spur gear without the motor in the car the left wheel is moving faster than the right.
When I put one wheel on my knee and spin the other the one on my knee doesn't even feel like its trying to move. Shouldn't it be trying to go somewhere?
The left wheel is getting so much more power that it literally melted the plastic hub adapter inside the rim.
Ive been stuck with this car for a while now. Whats Wrong!!
Any help guys. Some people have been telling me its the differential so I pulled out the diff but I cant see anything wrong? What should I look for to know if the differential is dead.
#6577
SC
differential grease it sounds like. did you take the differential appart? did you make sure that your outdrive yoks were attatched? sounds kind of like one is missing the screw maybe? you might have to rebuild the diff, but it sounds like one hub or yoke is messed up or missing causing the other wheel to recieve all the power when its on the ground.
#6578
Hmm im not an expert on this stuff so. Ill pull the diff open clean out the grease and look around see what isnt right. Ive got extra grease so I can fill it again
#6579
The differential looks fine... I dont see any stripped gears.. plenty of grease in there. I dont know what it could be???
My screws are present in both outdrives.. I dont know what else? Any more suggestions?
#6580
I have a question, is there any kind of Built in failsafe with the VXL RTR's? Or if you run out of range by accident does your truck keep racing off into oblivion @ 60mph, lol.
#6581
WA
I don't think so. Went out of range several times with a Futaba receiver and it goes in circles full-speed when out of range. Scary! [X(]
My TQ radio works well, but I can't seem to mount a receiver compatible with my Futaba 2PL 75MHz (which I prefer, came with my Evader Pro) right (Goes out of range probably because so much antenna is in the chasis, not out the top of the tube). Will using a Rustler battery hold-down and mounting the R122JE on it solve my problem? I'd like to know before I waste my money.
You might've stripped an idler (Are you still using a plastic one? Check it to make sure it isn't losing any teeth). This caused my Evader to run limp. But earlier today my Evader reacted strangely when a wheel wasn't screwed on right (that's what I get for using locking washers, stupid me!), but I doubt a loose wheel is the problem.
ORIGINAL: alextalaat
#6583
well i got my proline masher 2ks today for my vxl pede and rpm bullies, i also painted them to match my pede body, and i put my stock pede wheels on my xl5 rusty so now its a "monster rustler" lol, here are some pics.
#6585
yeah thanks, it was a little harder painting the rpm 2.2 wheels than the traxxas 2.8 wheels though, gotta go verrrry slowly lol
#6587
but you cant dye wheels 2 different colors in such small places can you? i like them to be green, black and chrome, you can dye wheels like that though?
#6588
ORIGINAL: veyron12020
#6589
lol exactly, but i think im pretty good at painting if you have seen my pics, i dont NEED to dye because i am skilled enough, with painting i can have green AND black AND chrome, and btw just so you know im not actually using like paint you use for houses, im using Krylon chrome paint, its used in airbrushing, painting rc wheels and bodies, and other kinds of things involved in hobbies, just so you know, thats just how I talk lol.
#6591
MO
i am pissed at my stampede right now lol. it has been un used for a while now but i finally got it back up and i charged the battery. duratrax 4200 7 cell. and it charged to 4200. i got some new brushes for my trinity speed gems 15t and put it all together. gearing 13/86 it was very slow. i thought that it was the gearing but i always used that gearing with wheelies and a lot of speed. so i put in the stock 19/86 and it was still slow as all get out. i then put my brothers duratrax 4200 7 cell in and it was better. but his battery wasnt charged all the way so it was still slow.
the main point is that i need a new battery. what is good? i want an 8 cell i think. i was looking at building one on this website.
[link]http://www.cheapbatterypacks.com/tstuff/v7/buildcustompack.asp?sid=1012592[/link]
but i am getting sick of the whole brushed thing so i might just be getting a sidewinder 5700 very very soon.
#6592
ORIGINAL: fusebmx13
I would get the vxl since you have the Stampede. It will drop right in and be FAST, cool temps, long runtimes, a great way to get into brushless.
Another good system would be the Mamba. But I wouldn't get the accual Mamba system. If you really want to do brushless right, get a Mamba esc, and a vxl motor.
Another outstanding combo would be the vxl esc along with the novak 6.5r motor. None of the systems are perfect, so for a little more, make your own.
The vxl is a strong system though, and the sw is too.
#6593
NJ
ok, I just installed new 5x11 bearings all around (wheels, tranny, etc) and installed a 35t pinion and a 76t spur. All I have to say is crazy tire balloonage.
#6594
ORIGINAL: pede_kid
#6595
NJ
soon.
I found that I had less top end with 35/76 gearing than with 25/90 gearing (12 cells). reason being is most likely because I was using 1500 NICD's (not exactly good performance). I think it's time for some ener-g matched packs
#6596
SC
for batteries, i would recomend hooking up with rcdemon. they do great work. the idler is a good possibility... but he is saying that one wheel does turn and the other doesnt... im not sure... axles or hex hubs maybe? pede kid, yeh we do need to see some videos of that thing.
#6597
ORIGINAL: pede_kid
soon.
soon.
#6598
NJ
ORIGINAL: Wipe Out
Or for that matter, Lipo.
ORIGINAL: pede_kid
soon.
soon.
I'd love LiPo though. Not sure about the safety of it.
#6599
ORIGINAL: pede_kid
Oh well there goes my summer jobs
ORIGINAL: Wipe Out
ORIGINAL: pede_kid
soon.
soon.
#6600
SC
hes got a good point. never looked at it that way. you take care of it, it takes care of you. haha. it really is easy if you get the right stuff. but you HAVE to get the right stuff. maxamps and hyperion are a great combo. i love mine. no problems at all either. i would take a lipo over nimh any day. and you say geared 35/76? thats a dang near 1:2 drive ratio... and its slower than the 25/90? you must have some issues there man. even on a crapo 1500 nicd it should still be faster. LOTS faster. im suprised you can even gear it like that...
