Gear Ratio Calculator
FL
Hello All,
I've found a very intresting program in my travels. This is a gear ratio calculator for R/C vehicles. It seems to work good, and I have had absolutly no problems with it (bugs, worms, general mayhem).
The site is
http://www.waits.net/public/rcgears/
You have to download it. It should take less then 2 minuts.
Gecko
The site is
Gecko
FL
RE: Gear Ratio Calculator
Do you know the outside diameter of the tire? It should say the outside diameter on the sidewall. And, you can change the mesurment units by clicking on the button.
On the motor, what is it? The manufacturer should have the specs if it is not indicated on the sticker on ths side of the can.
Gecko
Gecko
hey munkey, i got ya a speed calc if i ever get it finished. it includes all forces (air, friction,rotaign mass) and spits you out an estimated speed and hopefully some horsepower numbers(although those wont be very high)
