Stampede spur/pinion sizes?
AZ
My bro(aintskeered), as you may know is getting the reedy quad mag tomorrow. Pretty sure he will need to regear with the q-mag. I went to the gear wizard to check out which gears he should run to optimize the power and I came up with 87/16. That would put him at 0.13 tire/gear ratio. traxxas makes an 87t spur but not a 16t pinion. He will be bashing with his pede so will probably want more torque than top end. Anyone know of a spur/pinion set up that works well or someone that sells a 16t pinion? Thanks.
Tim
Tim
Banned
VA
RE: Stampede spur/pinion sizes?
Robinson racing sells the pinnions you want to get. Just go to tower and type in 16t... heres a good one: http://www2.towerhobbies.com/cgi-bin...?&I=LXEX14&P=7
