RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
The Evader Coalition ~ T.E.C.
Old 10-29-2008, 06:10 PM
  #12451
Evader-Revo master
Default RE: The Evader Coalition ~ T.E.C.
how I can peak it to 8.5 in a Gtb esc that only use 7.2
Old 10-29-2008, 06:19 PM
  #12452
SluggoMan
ORIGINAL: offroadjunkie
hey lug,cheech,rawfuls...i think i'm gunna sell mine...nothin wrong w/ it,just i seem to never have time to read rc car,let alone run it (at least till spring).anybody wanna buy me out for a fair price pm/email me.
you guys are still the greatest,btw[8D]
Tell us what you have on it. post some pix.
If I put the Mamba Max in my evader, will it blow everything up? Or can I just tune the thing down on the computer so it doesn't output so much, until I get a new diff. Is the diff all I need with all this new power?
Old 10-29-2008, 06:37 PM
  #12453
Evader-Revo master
I think yes you can don the power and yes you can use it with low power, if you want all power buy the conversion it all you need andmaybe a new metal gear servo
Old 10-29-2008, 06:42 PM
  #12454
rclugnut10
rclugnut10's Avatar
read the post below that i quoted my self in by mistake....
the lug
Old 10-29-2008, 06:45 PM
  #12455
rclugnut10
rclugnut10's Avatar
ORIGINAL: rclugnut10
the new diff and aluminum idler but you have the ext meaning you'll neen the evader style cases cuz they used different internal ratio's on the ext but
as for 6 cell batteries peaking at 8.5 if they're good batts they sould do that, i know people who have had 6 cells peak at 10v, it all depends on charge rates.... i charge mine a 5A (charger max) but some people may go 3ish or even 7 or 8 depending on the pack and all
if you charge at a higher amperage you'll get more power but less mha slower charge time will do the opposite, if unsure just do 1c ie on a 4200 pack 4.2 amps, also if your charger shows it, check the mha level at the end of the charge, my packs probally reach about 8.5-8.75v at about 2000mha but don't stop charging to 3000 (needs help...) and 4000 needs some help but its a 4200 pack and the other is a 3800... but my problems the point is, if you can look at the stats on the packs it's a good idea, before i left my nihm's for a month at a full charge (do not do or you will get above results store at half charge) the 3800 peaked at like 4200mha the 4200mha peaked at like 42-4800mha it all depends on use, so these packs hold more than they are rated for and put out more power than the lable says, keep in mind the better you're pack the more exagerated these results are, the guy who i bought these from said new they peaked at like 5000mha the 4200mha's so just thought i'ld throw that out there
http://www.rc411.com/forum/showthread.php?t=5985
that thread started by you're truely back when i was a uber noob, a guy did a thing on batteries, it starts at post 6 and goes onto the next page
ORIGINAL: Evader-Revo master
MG servos are a must for anything bigger than 1/16 or 1/12, and even they could use some, but if you're not crashing into stuff not 100% nessasary but they sure are a nice thing to have knowing that you'll probally never have a settering issue a al servo horn almost completly makes sure of that but i've been known to blow the odd bellcrank into next week....
the b2 diff conversion is soo worth it, look on the prevous page for info on finding it....
the lug
Old 10-29-2008, 06:46 PM
  #12456
Evader-Revo master
ok I peak it at max amp in the duratrax charger (the cheap $50 bucks). I will check the voltage but I not have the ampmeter
Old 10-29-2008, 07:46 PM
  #12457
SluggoMan
What's the best 4700 battery out there....I need max runtime for a 30 minute main race on a MM 5700. I'm worried I can't get to 30 min on 4700, but I don't want to go higher because I'll use the 4700 when they require 27t.
Old 10-29-2008, 07:52 PM
  #12458
rawfuls
Are you kidding? A Venom wouild probably do 20min...
Maybe a SPC battery?
CBP (CheapBatteryPacks) are GREAT!
Old 10-29-2008, 08:00 PM
  #12459
rclugnut10
rclugnut10's Avatar
ORIGINAL: SluggoMan
max amps makes some good 4700
if you're looking for a 4700 only you're short on opions but i know www.cheapbatterypacks.com makes some great batts and they have 5k's be sure to get the pack "upgraded"
the lug
Old 10-29-2008, 09:33 PM
  #12460
cheech4
cheech4's Avatar
someone mentioned beadlocks here. does anyone own beadlocks on there evader? if so please provide links... i would love a pair
Old 10-29-2008, 09:39 PM
  #12461
rclugnut10
rclugnut10's Avatar
well i know the evader rims are compatable with T4 rims and B4 if you got abuggy or wanna try somthing cool...
so if they do fit those then they'll fit the evader i think evader revo master had a link
yeah but those won't work well they will if we were to put a 12mm hex on but only the rears...
the lug
Old 10-30-2008, 06:05 PM
  #12462
rclugnut10
rclugnut10's Avatar
hey anouther double post by the lug
and i'm coping this one from RC411...
i just tested my badlands out, they are sick!!!!!!!!!!!!!! the traction is insane (just like me), i had my evader geared 22/88 which is just 1 tooth down on the pinion for a 1/2 in tire increase, and it was great, these things have soo much traction i can't belive it, i hardly spun out at all , they balloned a bit but hey a tire with a 1.77 in sidewall has rights to do that i got traction on:
loose rocks in my driveway
loose dirt in gardens (we cut them)
on wet grass
snow, (it's melting but we had like 2 in yesterday...)
i didn't get great traction on
my stone sidewalk,
my hard packed road
the road may be cuz it was either airborn or about to wheelie as i turned which lead to a pretty cool effect as it diffed out i did a 900 once and a few 720's the end of my body hates me from all the times it met the ground... all i can say is that these things are freakin' insane
okay done now...
some pics for ya
ID:	1062488   Click image for larger version
ID:	1062489   Click image for larger version
ID:	1062490   Click image for larger version
Old 10-30-2008, 06:19 PM
  #12463
rawfuls
Links for those sexii badlands?
Or are they just MT sized?
Old 10-30-2008, 06:51 PM
  #12464
rclugnut10
rclugnut10's Avatar
http://www3.towerhobbies.com/cgi-bin...?&I=LXTYP0&P=7
they're regular 2.2's and the price dropped $2 but they also gut um in 30 series if you want something a little lower profile and smaller dia....
the lug
Old 10-30-2008, 07:50 PM
  #12465
FairTax4me
FairTax4me's Avatar
I was looking at a pair of those yesterday at my LHS. They're friggin huge!
Lugnut, what motor are you running?
Old 10-30-2008, 07:53 PM
  #12466
rclugnut10
rclugnut10's Avatar
yeah they are HUGE!!!!!!!!!!
I'm running castles 4600 bl motor
WARNING USER MAY EXPERICE RANDOM WHELLIES!!!
the lug
Old 10-30-2008, 08:06 PM
  #12467
FairTax4me
FairTax4me's Avatar
Ahh ok. That would explain the large pinion. Large compared to what I can run anyway. Anything over 18 teeth and the motor overheats. I can probably bump up to 20 now that the weather is cooler. I run 25t on my velineon powered rustler riding on proline dirt works with no problem. Id love to go BL in the evader, but I still can't keep the diff from slipping, so BL isn't much of an option for me right now.
Old 10-30-2008, 08:31 PM
  #12468
rclugnut10
rclugnut10's Avatar
yeah what are you ussing in you diff for grease and such
i use this stuff on the balls
http://www3.towerhobbies.com/cgi-bin...?&I=LX2765&P=7
i just put a thin layer over all of them on both sides, i thighten my diff all the way down the back off 1/8 turn...
the lug
Old 10-30-2008, 09:55 PM
  #12469
Evader-Revo master
what is the difference of that grease and the MIP http://www3.towerhobbies.com/cgi-bin...?&I=LXAV73&P=7
Old 10-30-2008, 10:04 PM
  #12470
rclugnut10
rclugnut10's Avatar
probally none or very slight both are good just don't go overboard...
the lug
Old 10-30-2008, 11:17 PM
  #12471
Evader-Revo master
What you mean with "just don't go overboard...?
dont go without grease? I was using car grease, litium and other black car grease
that is for balljoints etc.. but i think that that grease doesnt help. one time also I use real car tranny oil inside the tranny, the tranny was noiseless but the oil come out of it because it not is sealed. I know you think im crazy using that all thing but that is because I not have the RC car greases
Old 10-30-2008, 11:21 PM
  #12472
rawfuls
Don't use too much grease. Too much grease = too much slop = bad.
Old 10-30-2008, 11:25 PM
  #12473
Evader-Revo master
ok, only a thin layer over the balls dff with de MIP, and the othe rparts of the tranny with the tamiya ceramic grease. what often i need to adjust the diff?
Old 10-31-2008, 11:53 AM
  #12474
FairTax4me
FairTax4me's Avatar
I use Permatex brake caliper grease because it doesn't sling off the gears. Its really thick, so it cuts down on gear noise and its still really slick so everything rolls easy. Maybe its too slick for inside the diff?
Do the new balls and washers have to wear in any?
Old 10-31-2008, 12:57 PM
  #12475
bloodyta2
I READ THE POST S HERE ABOUT WHAT I NEED IN MY EVADER BX TO RUN IT WITH A BRUSHLESS SET UP, BUT I COULD NOT FIND A " ALLOY IDLER GEAR FOR A EVADER NITRO" the LHS said its not listed, does anyone have a part number? what about part numbers for the other things i need too?
