!!!RUSTLER OWNERS WANTED!!!
WA
i know theres a rustler thread already....but aint nobody ever there!!!!! wheres all the rusty fans?....that thread used to be HOT...what happen?....if theres any1 out there still crazy about your Rusty please let me know!....we need to bring that thread back to LIFE!
IL
RE: !!!RUSTLER OWNERS WANTED!!!
ORIGINAL: KioIII
all the true rusty fans need to come back!!!!......and bring that thread alive!
WA
ORIGINAL: KioIII
What mods have you done to your rusty?
ORIGINAL: Haldir
My Rusty handles like a brick.
I lowered it about 1/2 inch off the ground and it still handles like a brick.
NJ
I'm a rustler owner and new to the hobby. I hadn't seen that thread in the forum; then again i wasn't looking for it either. I'll check it out.
I've had mine for about 2 weeks and haven't run it too much. It's bone stock, but I just ordered a set of P/L Dirt Hawgs and am looking into RPM's carriers and bearings.
Any good links out there?
ORIGINAL: Eugeit
The RPM carriers can bearings you mentioned are a great upgrade. The RPM wide front bumper is a necessity (if you drive anything like I do, you'll need it ) I'll put some links to good upgrades below:
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXNY89&P=Z]front bearing carriers[/link]
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXNY90&P=M]rear bearing carriers[/link]
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXEV91&P=M]wide front bumper[/link]
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXD122&P=M]bearings compatible with carriers[/link] You'll need 8, the link is a pack of 10.
WA
haldir and doahh....if you dont like the rustler stay out of Rustler posts.....geeee i wonder how hard that is?[&:]
NJ
Gunnut,
I've seen people saying the the Rustler and Stampede can be interchanged. I know that the chassis are different. What would be needed to raise a Rustler; shocks?, A-arms? Do you know?
WA
ORIGINAL: Bmr4life
I'd go [link=http://monster.traxxas.com/forumdisplay.php?s=&forumid=40]here[/link] if you want to talk to rusty owners.
ORIGINAL: Eugeit
Gunnut,
Gunnut,
adjust the shock positions to get more ride height. having the bottom of the shock mounted on the innermost hole should raise it up. If the suspension seems to "sag" when you set it on the ground, clip some spring preload spacers onto the shock, right above the spring. preload spacers are black(plastic) "C-shaped" clips that have a little tab on them-- there are different thicknesses to choose from. there should be a bag with two sheets of them that came with your rustler. Those are the easiest ways to raise it and it doesn't cost you anything.
Taller tires may give you more ground clearance... but then you may need to adjust your gearing to keep from burning the motor/esc. adjusting gearing isn't really a big deal-- a pinion gear costs around $3.00 and they're easy to access on the truck.
