sliper problem
sliper problem
how come win i set the slipper and give it gas it tightens right back up so it don't slip? the nilock nut is good! never had this problem on the nitro cars.
IN
RE: sliper problem
ORIGINAL: eforu
RE: sliper problem
actually most slippers get loose after driving. lubricating the slipper could cause serious slip action. more details on your slip-testing method are required to give you feedback.
RE: sliper problem
sorry it is a evader pro st. yeah if i loosen the slipper and the first time you jab the gas it tightens really tight i put some WD 40 on the bushings and it still does it and like i said the lock nut is good, the only way it won't tighten is if you set it to loose and the truck barely moves!
RE: sliper problem
i mean i have 2 tmaxxes a revo and a lx comp buggy so i can set a slipper and on the nitros the slipers will loosen but not tighen up donno
My Feedback: (18)
RE: sliper problem
I believe this is a common problem with the evaders, both of mine did it anyways.
Check the slipper bushings, the bigger one is liable to have gotten grooved by the smaller one, if that's the case you can either flip the worn bushing over or install a new one. (this would only be the problem if it has been used for a while).
If it's brand new and is doing it, I would suggest putting locktite on the nut or double nutting it (screw two nuts on then tighten them into each)
My Feedback: (34)
RE: sliper problem
Ya, the evaders do that. The nut is not good and easily can be tightened or loostened. In your case i would use loctite because double nutting it will just stop the nut form loostening, but it can still tighten.
