deans change
deans change
i am just curious, but i am considering converting over to deans. is it possible to change the connector on my current battery? i dont want to get electricuited when i cut the tamiya connector off... can someone tell me how to avoid this electruicution b/c even when batts are drained they still have a charge (i dont have a discharger)
PA
RE: deans change
It's only ~7.2V, you just don't want the wires to touch each other. When changing to deans read the back of the package, and do one wire at a time. You will not get a shock from touching the bare wire .
RE: deans change
You wont get electricuted. Worst case scenario, you'll make a couple sparks. You wont even be able to feel 7.2volts (unless you stick it on your tongue).
To avoid sparks, cut each lead individually. Dont just cut them both at the same time. After they're cut, dont let them touch.
ON, CANADA
RE: deans change
here's some good reading for changing from tamiya to deans:
http://www.misbehavin-rc.com/pit-lan...eans-plugs.asp
http://www.misbehavin-rc.com/pit-lan...-procedure.asp
Quote from article:
The first step, is to clip the connector off of the battery leads. It's best to do this when the battery is in a discharged, or near discharged, state. Also cut the wires one at a time, otherwise you short the battery, and take the chance of damaging it.
PA
RE: deans change
I use a 20piece pack on deans from ebay member [link=http://cgi.ebay.com/Deans-Style-T-Plug-Connectors-10-pack-20pc_W0QQitemZ6034548101QQcategoryZ34056QQrdZ1QQcm dZViewItem]world hobby[/link], I have had nothing but great expirience with him and my shipment took only 5 days to get here to Pennsylvania from Hong Kong.
CA
RE: deans change
ORIGINAL: skate5290
The only time you have to worry about the wires touching is with lipos, they can explode but nicads and NiMh packs will be fine.
RE: deans change
be careful with the heat shrink. I just got done changing 6 sets of plugs over to deans and the first two I did I messed up that heat shrink stuff. The wire must have gotten hot enough that the stuff shrunk-- to the point where it was real hard to slide over the connection.
I'm really glad I finally switched over to Deans though. It improved my sorta shaky soldering skills too.
NV
RE: deans change
deans rock. just tint the wires and deans with a little solder and then reheat the two together your done. make sure you have a decent iron and that you dont hold it to long or you will shrink the tubing and melt the plastic in the deans connector.
RE: deans change
depends if u already have wire and how your soldering skils are its usualy cheaper just to buy the plugs
also if ur bats already are made and have wire u dont reall want to add any wire on to them the longer the wire the more restiance ( boy im glad i had my adv elect classes in auto tech school lol)
NV
RE: deans change
just the connector. the batts come with plenty of wire or at least should so you would have to check the lengh and be sure. I can almost bet their is plenty. make sure you get rosin core solder. IMO that is what I use and have had no prob with it sticking. I actually buy mine at radio shack in a roll.
RE: deans change
ORIGINAL: cavfighter
Also make sure the tip is clean. I had lots of trouble at first because the gun wasn't getting hot enough. Use a damp sponge to clean off excess crud on the tip and it will work better!
MA
RE: deans change
I'm thinking about switching too. It's really gonna improve my soldering skills as I need over 30 plugs! lol. Would there be any advantage from this solder: http://www2.towerhobbies.com/cgi-bin...&I=LXJXJ2&P=DC
over radioshack stuff? thanks
My Feedback: (18)
TN
RE: deans change
I used Deans solder when I changed all my plugs and I am very happy with it. While I was at it, I made a pigtail to use on my charger since I didn't want to get rid of the tamiya plug for some reason.
OH
RE: deans change
I also use deans plugs and solder and love them. I know this has been mentioned several times already but, strip and then solder one wire at a time. If you are using nihm/nicd they will short and spark, if only breifly sometimes no harm.
But if you are using lipo's they can and will explode. Just be carefull. BG
MA
RE: deans change
well I wanted to use a solder that doesn't have lead in it just cause I have pets and its just something I don't want in my solder. Should I use the novak solder then? or the radioshack? thanks
PA
RE: deans change
the novak silver solder will have a slightly lower resistance than the 60\40 standard rosin core solder, you gain some added strength as well. The silver solder melts at a higher temp than standard solder just keep that in mind. Honestly if you are not a professional racer you are not gonna notice or care what kind of solder it is. If you go to radio shack and get lead free solder it is the same thing as novak's. Novak is 97% tin 3%silver, radio shack lead free is 96%tin 4%silver for the price just go to radio shack.
[link]http://www.radioshack.com/product/index.jsp?productId=2062722&cp=&pg=3&kw=
solder&parentPage=search[/link]
RE: deans change
ORIGINAL: Evader 53
