ESC Question
ESC Question
hi all
dont know if i will get any repies, but here we go.
i have a rtr tt-01 at the moment, and only had the upgrade berings, and i want to upgrade the electronics, i have a esc lieing about that is made for a boat, its a Marine 15 Speed Controller but a want to know if it sutable to work with cars and car motors, 540, or am i going to have to bye a new one. made for cars.
thanks
thanks
RE: ESC Question
Forwards & Reverse Marine ESC
Direct from the UK, Mtroniks have designed the updated, more intelligent VIPER range of ESCs.
The series consists of forwards only, reversible & marine spec controllers handling every job you can expect from the latest state of the art technology
NEW built in failsafe to protect against complete loss of signal or when out of range (compatible with all manufacturers receivers)**INDUSTRY FIRST**
ABSOLUTE short circuit and motor overload protection
15A current limit
Dual core microprocessor
6-12Volts input voltage
Adjustable features include programmable punch on the forwards only range and programmable reverse (including disable) & programmable brakes on the reversible range
4 Layer super power circuit board
Thermal integrated protection system
Digital one touchset up
Legendary 100% waterproof design
Dimensions : L39.0mm x W34.0mm x H13.0mm
Weight : 55g
All VIPER ESCs are capable of running up to 4500mAh cells & the latest high spec motors. Each VIPER ESC incorporates the latest state of the art technology and GEN-Xi power FETs
i could'nt find the package but i got this of the internet
15A current limit
Weight : 55g
RE: ESC Question
i doubt it will work fine IMO. with 15amps current limit, you MAY get away with the stock mabuchi RS540SH motor. anything more and will either burn out either the motor will run poorly. these ESCs [marine] are made to be used for high-efficiency large motors [such as graupner 600 or 700BB]. since it has overload protection, you might try it as well.
CA
RE: ESC Question
yeah a 15 amp limit isn't much and at the hit of the throttle you could easily go over that. I'd buy one made for a car. You can get one that will handle down to 12 turn motor for about $38.00 from tower hobbies.
RE: ESC Question
actually 15amps is the continuous current tolerance. the maximum [instant] would be around 60amps or so. thats about the same as with all stock escs [27-23t motors]. that marine esc would work fine as long as it is used with a stock motor.
RE: ESC Question
thanks all
it will be used with the stock motor
great help, im going to use this spped controler for now, and when i have some money ill bye
a desent car speed controler.
thanks again
thanks again
