Steering Problem
Steering Problem
Hello all, I have a Evader St Pro after stripping out the steering servo that came with the Truck I installed a Hitec 645mg servo. I now have a bad steering problem. Before replacing would drive stright. Now goes left all the time and after adjusting the steering trim it dosn't seem to help. Also feels like it is steering backwards from before meaning what was turning left on receiver is now right, WHAT DID I DO WRONG
Thanks for any help.
CA
RE: Steering Problem
take off the servo horn and turn on the car... You need to take the servo out
Center the trim and THEN put the horn back on AS STRAIGHT AS POSSIBLE while the system is still on and servo is centered.
Reinstall into the car
Flip the Chanel 1 reverse switch
