battery wires too hot
iam running a losixxx4g+ with peak racing 15turn motor and mtronics viper rv 11 esc with a 3600mah batt
after about 5-10 mins of running the batt leads get very hot so hot its blacking the pins on the conection
is this normal
is this normal
TX
RE: battery wires too hot
Its normal when they can't handle the current going through them. Upgrade to the "Deans Style" connectors.
They look like this:
http://www2.towerhobbies.com/cgi-bin...&I=LXKX39&P=ML
MA
yup tamiya plugs have a lot of resistance, the deans plugs are considered "loss less" as they only have as much resistance as the equal length of 12 gawg wire. I think you should leave your wires as they are unless they are in bad condition. I would also replace the bullet connectors going from your ESC to motor, they have quite a bit of resistance too...
For 1/10th scale it is always safest to use 12-guage and dean's plugs. Sometimes the connectors themselves heat up, and then the heat is carried through the wire.
QC, CANADA
you should get thicker gauge wire, and also shorten them. shorter and thicker wires makes less resistance. therefore less heat. also id suggest deans connectors.
eric
eric
GA
Like everyone said, get Deans and either hardwire your motor or use Deans there too. This should give you more power and make virtually no heat in the wires and connectors.
The tamiya plugs are prone to loosen up after a while, the actual white plastic plug may seem snug fitting but the actual connector inside is loose, this causes it to heat up easily.
Like others said, use dean's plugs.
how do you mean side by side iam quite new to all this?
ps thanks to you all ive now hard wired my motor and fitted deans plugs and its much better more responsive and i think quicker once again thanks alot
I have this same problem but only when i charge my battery because i charge it with alligator clips and the clips are connected to the charger with a tamiya plug. I use duratrax powerpole connector on all my stuff, motor battery etc..
they are made out of silver and it like having everything hardwired. they're the best. here is the link.
http://www2.towerhobbies.com/cgi-bin...?&I=LXD175&P=7
MA
ORIGINAL: fernandorussell
ON, CANADA
1st pic is a stick pack like yours, second pic is a side by side pack. In a stick pack the cells are held on top of each other by little tin strips that are usually spot welded in place. A side by side packs uses soldered on battery bars which have much less resistance. If your gonna be making a side by side pack I recomend deans battery bars. I think powerpoles actually have a tad less resistance, both are lossless connectors meaning you have less resistance than the same length of wire so it does'nt really matter, I like deans cause they only connect one way.
MA
ORIGINAL: hands without shadows
Antsb I do not reccomend that you convert your packs to SXS. SXS is better but it is a lot of work and you need a very strong soldering gun to do the job. Unless you are running brushless or really low turn motors you won't notice a difference at all.
