Good Racer???
Good Racer???
Would This Be A Good Racer???
Tamiya 1/10 Nissan 350Z Racing Kit http://www2.towerhobbies.com/cgi-bin...?&I=LXFDN6&P=0 69.99
Tamiya Aluminum Propeller Shaft TT-01
http://www2.towerhobbies.com/cgi-bin...?&I=LXETM7&P=Z 6.69
Tamiya Ball Bearing Set TT01
http://www2.towerhobbies.com/cgi-bin...?&I=LXBUA9&P=Z 18.99
Tamiya Anti-Wear Grease
http://www2.towerhobbies.com/cgi-bin...?&I=LXWB00&P=Z 8.39
Tamiya On-Road Touring Spring Set 62
http://www2.towerhobbies.com/cgi-bin...?&I=LXGH23&P=Z 10.59
Tamiya Anodized Flange Locknut 49
http://www2.towerhobbies.com/cgi-bin...?&I=LXGH20&P=Z 7.99
Tamiya Pin Type Wheel Adapter 81/49 (4)
http://www2.towerhobbies.com/cgi-bin...?&I=LXGE28&P=Z 5.79
Tamiya AV Pinion Gear Set 20T/21T 49
http://www2.towerhobbies.com/cgi-bin...?&I=LXGJ69&P=Z 6.69
Venom Magnetics Python w/26mm Super Tire (2)
http://www2.towerhobbies.com/cgi-bin...?&I=LXHUK8&P=7 11.99x2=22.99
DuraTrax Streak Forward/Brake Hi-Frequency ESC J
http://www2.towerhobbies.com/cgi-bin...&I=LXD523&P=ML 34.99
Trinity Cobalt 12T Double Flat Wire Modified Motor
http://www2.towerhobbies.com/cgi-bin...?&I=LXJHE5&P=7 54.99
2PL AM R142JE 1 S3003 88 75950
http://www2.towerhobbies.com/cgi-bin...I=LXENN388&P=7 64.99
314.07 - 30 = 284.07
RE: Good Racer???
well, the tt-01 is a good stable chassis to start out with, but i think you should buy a tamiya ta-05, much more solid, and has many many more upgrades avaliable, only thing is that it isnt shaft driven, its belt driven, but that should give u a little bit more accel, and you can upgrade everything to carbon fiber down the raod if ur interested, they sell a huge selection of parts for it on ebay, adn with the right motor/ pinion (and esc ofcorse) you can make that baby go super fast, its also not bad for the stock, which is pretty speedy.
