Wtb: Vintage Team Losi Jrx pro parts
Hi all
im new to this forum and i have an old Team Losi Jrx Pro that my father used to play with it but now its my turn
Id rather know if anyone in this forum have any parts for this car or even the car itself
or if someone know a store or something where i can get parts
if anyone expert with this vantage, i would like to ask you some questions...
this is what the car look like
thx to all of you
thx to all of you
RE: Wtb: Vintage Team Losi Jrx pro parts
manual
http://www.oople.com/rc/manuals/jrx2...rx2advert.html
parts # list
http://www.rcchopshop.com/losi/losijrx2.html
best place for parts is ebay
or here
http://www.marketworks.com/storefron...79026&c=301123
parts # list
or here
first, thx a lot for the information provided...
Right now im pretty fine with the spare parts....
but i would like to get new tires and a new body
where can I get that?
Also, I was wondering if I can replace my old batteries by new one to get more power...
if yea what sould i look for (which batteries, charger, plugs)
Replace antenna by a shorter one... is it possible
get a new speed control, motor?
thx a lot
thx a lot
u can use any new bats i would reccomend 3300 or better as for a charger a good cheap one is the vision peak
http://www.dynamiterc.com/Products/D...ProdID=DYN4045
im not quite shure what rims wil fit the jrx so u might have to ask around a bit or check ebay for rims
the only way u would be ablre to shorten ur antenna would be to buy a diffrent reciver that had a shorter wire
as for a body i just checked and didnt find any stock ones on ebay u migth just have to try diffrent bodys to looks like the associated rc10 viper body might fit
[quote]ORIGINAL: discgolfer72
any brands and website for batteries that u recommend for my car...
if i change the batteries, i will have to get new plugs but do I need to change also the motor, thespeed control b/c batteries are better?
smaller receiver??? where can i get that? does it fits in every car?
thx
thx
ORIGINAL: ThunderbirdJunkie
Do a google search for W.S. Deans bodies, they've got one for the JRX and JRX-2
thx
u had said u wanted a shorter antenna well some recivers have shorter wires coming off the reciver and that s the only way u would have a shorter antenna u dont want to cut the one u have
as for getting a shorter one check tower hobby aor ebay and look for just about any newer reciver i
i just got 2 recivers and a controller for 15 usd off ebay they are stock elect from a rc18 t and are verry small and have short antenna's i think they call them xps recivers
as for the bats as long as ur car has standard tamiya plugs (white plastic connector) u will not have to change ur connectors(i do reccomend swaping them all to deans connectors tho )
and u should not have to change ur esc /motor unless u want to for more speed
what esc do u have now
any newer reciver as long as its am (if thats what ur controller is check to see if its not fm but im pretty shure its am ) and 75 mhz will work
the xps ones i got r 27 mhz so they wouldent work but like i said i got 2 and a controller for 15 $ and u cant buy a reciver new for less than 20
i looked a little closer at ur pic looks like u already have deans on ur bat (red connector ) if ur esc has the same(im guessing it does) then u will have to change ur bat conectors when buying new ones
but if the receiver, and the controller are still working pretty good, I can keep them...
but like i said I would like to get a new antenna because I dont like the one that i have now...
I try to find tires and a new body on internet for my car but cant seems to find any...
u recommend any brand for the batteries?what type?
pictures
[img][/img]
[img][/img]
[img][/img]
[img][/img]
pictures
[img][/img]
[img][/img]
[img][/img]
[img][/img]
as long as ur car is working thoes things will be just fine i run tons of old elect in my cars with out problems
that connector looksd like a micro connector so if i were u i would go ahead and get regular deans
http://search.ebay.com/deans-connect...sopZ3QQxpufuZx
as for bats
im guessing u dont have raido shacks in canada so ur sol on the cheap gp 3300
but i recomend any gp or ib nimh cell packs 3300 mah up (6-7 cells)
http://search.ebay.com/search/search...trypage=search
http://search.ebay.com/ib-3800_W0QQc...ZWLRSQQxpufuZx
as for bats
should I look for higher than 3300 mah or 3300 is fine for ym car?
for deans plugs, I need to get male and female??
is there a package that has what I need?
is the price high for plugs on ebay?
there are some radio shack in Quebec, but now, mostly, we have La Source...
3300 is fine
those links above have price and info on deans
u will need frmale for ur bats and male for esc
then one female for ur esc and one male for ur motor
raido shack in usa has gp 3300 for 25usd
I bought today 10 pairs of deans plugs.... 11,67$ cdn I think its a good price...
I need an advice, I dont know what to do
I will receive soon the deans but im wondering if I change the old plug for the new one right now if I dont buy new stuff... maybe later
bc getting new batterie that has deans plugs, I will have to change all my equipment plugs by the new deans plugs...
Should I buy new stuff for a vintage... this is the question...
car working pretty good right now and I have lot of spare parts now...but I could get a better car...
also if i get a 3300 mah batterie, does my motor has a chance to broke?
if yes that means a new motor...
disgolfer do u have msn messenger?
no msn
most of my cars are vintage and i have had better luck whith them over new cars but parts are hard to get when u brake stuff
so its really up to u
if u have the money and the car u have now is running good (the way it is)then buy a new rc car and keep the old one to . the rc10 t4 or b4 and the losi xxxt and xxx are verry good new cars with plenty of replacment parts and hopup parts
i would use the deans i dont know what type the connectors are on ur car now bud deans are very good and will increase the power of ur motor over regular plugs
as for ur bast as long as ur running 6 cell packs u will not have to worrie about the new bats hurting ur motor or esc u might want to get some new brushes and springs for ur motor tho just to give u a little better speed (by the way do u know what motor r u running)
Yea I will change my connectors by the new deans...
I dont know what motor I am running lol...
this car is to my father and hes not playing with it anymore so he doesnt remember and for myself I just startin in Rc car so, I dont know yet how to remove the motor lol
Maybe I can spend some cash on the vintage to get it better (batterie, motor)instead of getting a new one... b/c I dont have much time and we dont have a lot of tracks in Quebec and I dont know yet if I really like Rc car bc i never went on track...
btw if I change the batterie, I need automaticly a new charger?
The first thing to do is get on the track to see if i like that and if my car suck ass lolll
it all depends on the charger u have
u need to find out if it will charge (nimh) bats or (nicd) does your bat say one of thoes on it and what kind of charger do u have
pic of the charger... 12 amp max, 13,8 vdc if it can helps
[img][/img]
my batteries are nickel cadmium battery N-1400SCR , 1.2v , 1400 mah
[img][/img]
pics dont really help
is there any model # on it and i cant tell if the charger is the tekin thing or if thats just a powersuply
do a googe search for the brand and see what u come up with but if the charger is more than a couple of years old u will need to geat a new on that can charge nimh bats or just get some good 2400 nicd bats (but thay wont be as good as the nimh ones ) i reccomend the vision peak its cheap and works great i have had mine for 2 years now and had no problems
