is this a good....?
is this a good....?
Tazer 15T Forward/Reverse ESC
http://h1069914.hobbyshopnow.com/pro...p?prod=DYN4925
My wife and I always buy eachother stuff we want instead of suprizes for Xmas because its easier that way..so i'm trying to find a decent ESC for my bandit among other things...
It's only $30 and shes going to hobbytown next weekend to get my micro-T and some other stuff i probably dont need =P
heres the motors i'm looking at
Method R Modified 15T, Double
http://h1069914.hobbyshopnow.com/pro...?prod=ORI25112
Raven S Modified 15T, Double
http://h1069914.hobbyshopnow.com/pro...p?prod=PEK1253
Speed Gem Pro,Titanite,15T,Dbl
http://h1069914.hobbyshopnow.com/pro...p?prod=TRI9253
Intense 15T Double
http://h1069914.hobbyshopnow.com/pro...prod=EPXEP1120
I'm not goingallout with this bandit..just gonna mess around with it a little..my dad is also building my other one..
Intense 15T Double
RE: is this a good....?
Honestly you don't need to bump a thread the same day you made it. It's rude and pushy.
EDIT: Woops, excuse me, sorry
I read the month as the day. My appologies.
To your question though.
I would go for a Reedy Quad mag 19t. I know it's not on your list but it is a great motor for 1/10 buggies and ST's. It was my favourite motor I ever owned. Had way more torque then my brushless, not quite the RPM though.
That ESC is on the cheaper side, but it will do.
Also make sure you are using deans plugs.
actually someone suggested the reedy quad mag..i knew it was a better choice i just wanted opinions on the others...i'm probably going to go with the reedy just because it's been reccomended twice now
the deans plugs...are they more efficient or whats the deal with those..i was gonna pick some up the other day but they were completely out at my local shop (go figure,they never have anything)
Probably they didn't have them because they are so popular.
The deans plugs offer lower resistance when joining your ESC and batterery (just solder the ESC tires to your motor). This means you car goes faster and accelerates faster, running more efficiently.
I really recomend them.
ORIGINAL: bIGmiK
OR
i use that esc with a method 19t double in a stampede. more power and speed with longer run times over stock. it is basically my 6 yr olds now. it is inexpensive and works well enough for me
