View Poll Results: A poll
Voters: 22. You may not vote on this poll
4.5 or 5.5. Whats faster?
RE: 4.5 or 5.5. Whats faster?
Maybe you meant slightly less torque..
As 4.5 will put out more power than the 5.5
ORIGINAL: Bombers_410
the 4.5 will spin at higher rpm, but will have slightly less power. lol who voted for the 5.5???
Depends on your definition of faster. For what? Offroad or onroad? In what car/truck?
By your logic, surely a mamba max 7700 would be faster than the 5700, but it isn't in most applications...
ORIGINAL: Lilredmachine
FL
Ok guys dont get off track. Unless your racing off-road ten the 4.5 is definetly faster then the 5.5. Igf your racing offroad thne both of them would be too much power, and you would spin your tires. If your bashing, or racing on-road, then definelty get the 4.5
FL
ORIGINAL: Lunchboxer
"What is faster..The GTB 4.5 or 5.5??"
Since the 4.5 turns more rpm per volt than the 5.5 and both are rated for 7 volts the result is clear. The 4.5 will spin faster than the 5.5 given the same load up to the brake over point which you will not reach in a 1/10 car unless you lead weight it to death.
FL
ORIGINAL: CheapSpeed
This is not true. Becuause you can not run 3s lipo on the 7700, which you can on the 5700. which inturn pumps out more RPM. making the 5700 FASTER.
