Stampede caster block change question
IL
Howdy all, I've got the Stampede XL-5. I've just now put on the FLM extended arms, and just noticed that the holes in the stock Pede caster blocks have too narrow of a hole to hook up to the FLM arms using the FLM rods. Stock Pede rods screw in, and won't work either.
Are there decent Pede caster blocks that folks use for this type of thing, with a wider diameter hole where the rod hooks the caster block up to the end of the lower front arm?
Thanks!
Thanks!
