help with gear mesh
help with gear mesh
I keep shaving the teeth on my spur gear and the truck will make funny noises when i press the throttle. At first after setting the gear mesh the truck runs fine but after running it a while the truck will make funny noises when i poress the throttle and ill look at the gears and the spur gear teeth with be shaved a little. So how do I make sure my gear mesh is good? It looks fine when im setting it. I noticed that the pinion gear moved. I screwed that tiny little screw into the pinion so it would hold onto the motor but i guess it came loose. How do I make sure the screws dont come loose?
My Feedback: (35)
RE: help with gear mesh
ORIGINAL: Jerohmeee
