Help my list (not Christmas)
Here is what i have so far for my pede:
Rpm carriers front/rear: LXNY89 front/ LXNY90 rear
Duratrax stainless bearings: lxd125
Rpm chamber links: 81262
Rpm rear Shock tower: 80832
Rpm Lower shock cup: 73155
Antenna cap red: lxjgu9
Traxxas steel drive yokes: lxjg59
The bearings/carriers are a must have. The chamber links i heard were good. the shock tower, just looked stronger then stock. the lower shock cup i thought would look cool in blue, same with the antenna cap. The steel drive yokes I heard are a good thing to have.. let me know.
This will be because I got good grades.. I still have to plan what I want for Christmas. I am looking for durability and efficientcy.
Always Dreamin[8D]
Always Dreamin[8D]
CA
RE: Help my list (not Christmas)
FLM parts!!!
in my experience the only RPM parts I like for the pede are the bumper, esc plate and gear cover. I would personally go with a FLM and traxxas aluminum front caster block and bearing carrier, I often bent the pin before I went aluminum.
RPM a arms are worthless, much more flexable than stock. I have never tried the RPM shock tower so I cant say...
Unless you wana mess with the camber why even bother with turnbuckles, for bashing the camber is stock just fine.
Save up for a burshless system!!! , if you dont already have one. Theres no need to really upgrade much on a XL5 pede! If you break it, then upgrade.
Aside from brushless the next best thing is to widen the pede, and IMO the best way is FLM!!! direct bolt on, even makes it a little longer!
Skip the RPM parts, VXL carriers will do just fine. Don't get the Duratrax bearings, pick up a set of TBS bearings off ebay. Get the Rustler/Pede pack, which has 8 5x11's (for the wheels) and 8 5x8's(use 4 in the steering bellcranks). The RPM camber links are a waste of money...either keep the stock ones, or upgrade to adjustable links. You don't need the steel drive yokes; way too much money for what they offer. All you need are the stronger, black plastic, VXL yokes. Going somewhat along with the guy above me, you really don't need any FLM parts, except for the caster blocks, possibly. They'll just make your truck heavier. I highly recommend doing the HPI wide conversion, you'll love it. And don't forget the steel idler, if you don't already have one.
CA
Personally on my truck I currently have FLM extended arms, FLM caster blocks, and traxxas bearing carriers, swami bar, MM5700, and metal camber links, integy maxx MSR5 shocks on rear. Sure the truck weights alot, but halls but with my 9.6v 4500mah packs. I beat this truck silly so strength is key.
I plan on getting a FLM extended chassis and possibly a new charger to handle custom 12 cell packs and maybe lipo someday.
PA
youre doing it right... rpm is the way to go. Ive never broken an rpm part in my life. The duratrax bearings worked great on my rusty... I think they are fine. You could look in to getting MIP cvd's, but they arent necessary. looks to me like youre truck should be pretty bullet proof as it is. Maybe you should spend the money on nice batts or w/e.
ORIGINAL: barefootdan
rpm shock arms?
rpm shock arms?
My Feedback: (23)
WI
ORIGINAL: Always Dreamin
i think that might be a waste of money. i'm not looking for looks or anything. just a durable truck.
rpm shock arms?
rpm shock arms?
ORIGINAL: Takedown
Most definately not! I have the blue rpm arms on my rustler and they absolutely rock when it comes to durability. Ive already snapped one front stock arms and I've landed numerous times on all the arms even in the middle of winter and nothing bad has even come close to happening to them. Also you might wanna look into the SRT fiberglass tiebar and the RPM casterblocks.
rpm shock arms?
rpm shock arms?
My Feedback: (23)
WI
Well the things your really going to "need" are the rpm bearings carriers, duratrax 5x11 bearings (8x), Both F/R RPM shock towers, Jato universals and stubs, RPM castors.
ORIGINAL: Takedown
My Feedback: (23)
WI
Jato universals- http://www3.towerhobbies.com/cgi-bin...?&I=LXKMG2&P=Z
The only reason you'd want to upgrade to Jato shafts is if you have a problem stretching the u-joint holes or twisting shafts with a hightorque brushless system. The jato shafts have thicker u-joints. If you were interested in that conversion, you'd jsut pick up the L&R half shaft set, not the one previously linked to. Then pick up a set of VXL output yokes and stubs (it's not confirmed yet if the VXL stubs are more durable and made of a better material than the old stubs) and drill them out to fit the Jato shafts. The Jato output yokes will not work without extensive modification and the Jato stubs use a 5x11 and a 10x15 bearing, so they will not work either.
My Feedback: (23)
WI
ORIGINAL: kavvika
By universals, do you mean the slider shafts, or the u-joints? Yes, I agree the Jato shaft conversion is great for durability, but you shouldn't have a problem running a brushed motor. Have you tried the new VXL stubs, and can you confirm that they are more durable than the old stubs? I can't get a straight answer anywhere.
My Feedback: (23)
WI
ORIGINAL: kavvika
CA
I dont get how anyone would have a problem with the stock drive shafts, I haven never broke mine after running years of brushless from 7.2v SS5800 to 9.6v MM5700
IF ITS NOT BROKE DONT FIX IT!!!
#1 get a decent brushless, #2 go wide with FLM, #3 get FLM/traxxas aluminum steering blocks and bearing carriers
RPM has some nice stuff but the arms SUCK, I bet the shock towers are just as flimsy, yeah they wont break, but they are as flexible as a wet sponge!
