Code for 50$ + (new) good battery? if not what to get?
RI
NEW TOPIC
I was thinking of getting a 8.4v battery for speed for my titan which is a temporary motor untill i get the mm. this a ok battery? http://www.all-battery.com/index.asp...OD&ProdID=1961 i know there are better battery packs but i only want to spend $50- for a battery
OLD TOPIC
i bought...
Traxxas Main Diff w/Steel Ring Gear
Traxxas Idler Gear Steel 30T
RPM Bearing Carriers Front Rustler/Stampede
RPM Bearing Carriers Rear Rustler/Stampede
DuraTrax Bearing 5x11mm Stainless (10)
RPM Gear Cover Sealed Blue Traxxas Electric
Traxxas Grease White Lithium
Traxxas 23T Pinion 48P w/Set Screw Steel
all for $52.32 at tower hobbys
is there a code that still works where i can save some $$ with orders 50$+?
OLD TOPIC
i bought...
RI
RE: Code for 50$
ORIGINAL: Always Dreamin
he means a super saver club member. you have to pay for it.
ORIGINAL: hockey911
i signed up for the e-mailing adress thing
RE: Code for 50$ + (new) good battery? if not what to get?
just check towerhobbies..
http://www.towerhobbies.com/ssc/index.html
ORIGINAL: hockey911
any1 reccomend a good battery that is 3800 mah + less than $50?
SK, BANGLADESH
you don't have to pay for a darn thing to get the coupon codes
they email them to me all the time (especially when I haven't bought anything in awhile)
RI
i made a pack on cheapbatterypacks.com it has...
7 cells $5.70 each so 39.9 for all batterys and i got a Upgrade Charge which is end to end solder and copper bars where applicable. Makes for the lowest resistance. for $7 in all which is a total of $46.90 for everything, good deal?
ORIGINAL: hockey911
RI
ORIGINAL: kavvika
010L5 is good for $10 off $25
My Feedback: (23)
WI
This might help- http://www.retailmenot.com/view/towerhobbies.com
hockey, I never "received" that offer from TH. I found it online (retailmenot.com) and when I put it in, that message did come up off to the side of the screen. However, the code was accepted when I placed my order this morning. I believe it's just a generic message that you have entered a code, and either it works or it doesn't.
Also, TH might have a list of everyone who signed up to recieve e-mail offers, and only let them use those codes. So you might want to try signing up and then logging in with that e-mail address to see if it'll take.
RI
my dad went to my lhs to talk to them about lipo now my dad probably will buy me the mamba max 6900kv esc anmd motor and hopefully in 1-6 monsths he buys me a lipo battery and charger and balancer
balancer : http://www.maxamps.com/Apache-505.htm
battery : http://www.maxamps.com/proddetail.ph...74-Pack&cat=74
charger : http://www.amainhobbies.com/product_...ducts_id/18361
any other reccomendations? other than these?
RI
ORIGINAL: kavvika
ORIGINAL: hockey911
RI
yeah gonna get it
nope. you should check out that free dvd tho. it's very informative in my opinion.
ORIGINAL: hockey911
If you're up for soldering, those 3300mAh 8-cell packs w/ deans at all-battery for $15.99 would be prime candidates for a rebuild.
RI
ORIGINAL: kavvika
ORIGINAL: hockey911
charger is only up to 7 cells
ORIGINAL: kavvika
don't know if you could get a good battery for $50. especially not 7 cell. you should spend the money to get the maxamps NiMh packs.
Yeah, pick up the 8-cell pack (since it's the cheapest on the site) and rebuild it using 7-cells
