My 1st Belt Driven Tamiya - Durga DB-01
This showed up at my door today, courtesy of RCStation!
Didnt expect EMS to be so fast!
I will document the (slow) build of this kit - as well as all the screw ups I'll make
RE: My 1st Belt Driven Tamiya - Durga DB-01
I dont know if this is the same kind of Lexan I got previously for my Dark Impact.....it seems less 'shiny'.....
Chassis material is not the same as the Dark Impact - DI's chassis is a black shiny plastic, this is more matted and grayish, kinda like the same material as the suspension arms of the DI... wonder if this is stronger?
I dont know if it will fit side by side packs - cos I dont have any. This pack is probably the longest lengthwise that would fit without any mods or cutting. Breadthwise, for this pack, there's about 8mm to play with. Pack's approx dimensions: 139mm x 45mm x 20mm
The tires are about the same size as the Dark Impact's. Lucky me, I have Dirt Hawgs somewhere in my room......somewhere......
Looks great!! It should be a good buggy!
Setup sheet for a Tamiya, wa!! First time I have seen it! ha! (but then I never owned any TRF cars... I bet those would have setup sheet..)
ORIGINAL: Lunchboxer
If the Durga is based on the TRF501X then it shouldnt do too bad, heh. Setup sheet is a first for me too - wonder if it's really useful (for a non racer like me)
ORIGINAL: barefootdan
how much was that beast?
You can get it from other places, eg eBay, Tower ..... but for me rcstation was the cheapest. eBay, the last time I checked, had only one seller and the price was much more.
ORIGINAL: wookie_racer
looks great! i have been looking into this buggy. i can not wait for some updates!
ORIGINAL: yellowfuzzle
Sweet, looking forward to the rest of the build....
Also, taking some experience from building up my DI, I'd think of first purchasing the hop ups that are available for the kit, and THEN build up.....
Interesting note: Before I bought this kit I was set to buy TRF501X hop-ups for it. But after reading the manual, apparently there WILL BE DB-01 dedicated 'essential' hop ups..... (eg slipper, front one way, etc)......
the body is less shineyer cuz it has a over spray protective coating that you remove after painting
and the chassis is made of carbon plastic
alot stronger then the plastic the DI is made of
I'm toying with the idea of getting one..........I look forwards to watching your build progress....and your overall opinion of it after you've given it a thrash
Number 2
Main chassis - quite easy. Note to all - do not use hex screws for new holes! I stripped a couple here. Plastic is DEFINITELY harder than DF03 has.
Motor mount is made of some kind of ceramic material - kind of like the sharpening stone kind......
First thing I noticed which was interesting to me- chassis has option for you to change caster settings!
Number 3
Differentials, front and back. I used quite a lot of ball diff grease and really smeared the diff real good!
Number 3
Decided to use these-although I think on hindsight, it's not really necessary since the drivetrain is sealed up quite good (by the looks of it).
Can't throw these away though!
Number 4
Rear differential cover. I have a weak spot for blue bling, which explains the hop-up blue hex screws you can see in the pic [sm=bananahead.gif]
Number 6
First pic shows the finished product - belt tensioners. I had to double check if I placed the correct tensioners at the correct sides.
Second pic shows the rear differential in the chassis.
Number 6
This is the plastic part that seals the aft part of the motor mount. Neat idea to seal the drivetrain, I feel
Sorry for the darkish pic[]
Number 7
Rear diff cover attached to chassis. One piece of advice - make sure you double check that you have done all you need, because it's quite tiring to screw in the 6 screws! (Actually I only remembered to use the differential seals AFTER I screwed the six screws in )
