why is it like this?
RI
say i got a 3s lipo battery for the vxl it says it reaches 70mph
but wihtt he mamba max 5700kv motor it says with a 3s lipo battery it goes 60mph when the mamba max has more kv, why is this?
RI
RE: why is it like this?
ORIGINAL: sloppyG
gearing my friend, it's all in the gearing
vxl?
mamba max (if so enter kv amount)
vxl
also how much of a difference is it from a 7.4V lipo battery than 11.1V lipo battery?
would i have to use the balancer on the truck with a lipo? no right?
RI
ORIGINAL: brushlessboy16
not exactly, the kt rating of the vxl is higher, it makes mmore torque so u CAN gear it higher
NJ
the dffernce betwwen 2s and 3s in these motors is Night and Day....
on 2s the vxl turns 25,900rpm unloaded
on 3s it turns 38,850rpm
more then 10,000 more rpm. big differnce
RI
DANG I FORGOT ABOUT THE CHARGER AND BALANCER! LOL JUST KIDING
battery : http://www.maxamps.com/proddetail.ph...74-Pack&cat=74
balancer : http://www.maxamps.com/Apache-505.htm
charger : http://www.maxamps.com/Eos6i-AC-DC.htm
any reccomendations than the ones i found?
this sounds dumb, but on the charger does it stop from overcharging? yes right? lol
Here is what I use for charging Lipos.
Balancer http://www.commonsenserc.com/product...roducts_id=184
Lipo voltage meter http://www.commonsenserc.com/product...roducts_id=331
Lipo Charger http://www.multiplexusa.com/RC-comp/...rs/LN-5014.htm
Power Supply for charger http://www.ripmax.com/item.asp?itemi...0&Category=070
RI
what about this?
http://www.visionhobbies.com/1381312.html
expensive but good w/ a built in watt meter
SK, BANGLADESH
ORIGINAL: pede_kid
The MM7700 may be faster on a 2s LiPo.
you can run 3s on the VXL (or 5700)
ORIGINAL: hockey911
yeah, now im starting to go towards the vxl
RI
ORIGINAL: Always Dreamin
make up your mind
ORIGINAL: hockey911
RI
if your getting a vxl get run 2 packs on it to get a decent rpm... otherwise ur not gonna be going very fast
NJ
becuz u need motor rpm to get speed ok?
More voltage equals more rpm.
The vxl only has 3500kv. very low. it will only give u a high speed if you put more volts to it to get more rpm.
stop posting soo many threads, use ur questions page
