motor fan and/or heat cync
RE: motor fan and/or heat cync
My Feedback: (23)
WI
A heatsink will do fine. The heatsink fans dont tend to last long because of all the debris that gets caught in it and it chews up the fan blades.
TX
You won't need a heat sink or fan with the Novak 10.5.... I run a 3.5 and I don't need one. Unless you are running some really ridiculously tall gearing that is the only thing I can think of... or using it in a heavy vehicle.
ORIGINAL: barefootdan
what about for a vxl?
yeah just a 6 cell 3600 mah
I'm going to run a 10,000 mah lipo at 7.4 volts in a Exceed dynamite 4wd MT. Is it true these BL motors like to run, so gear them lower and they will run cooler?
