lipo and charger questions
RI
If i am getting this charger http://www.maxamps.com/Eos6i-AC-DC.htm with this battery http://www.maxamps.com/proddetail.ph...74-Pack&cat=74 i would not need to buy a balancer because in the charger's description it says "This charger balances your pack while it's charging." so i deont need a balancer? and since the battery i want to get is 7.4 Volts would it work with this charger although it says "11-15V DC or 110-240V AC " but it also says " 1-6 Lipo" so can i use this battery wiht this charger?
is it possible to cycle lipo batterys? why or why not?
with this charger in order to charge my batterys do i need to buy a cord in order to charge from a dc?
NJ
RE: lipo and charger questions
yes you can use the charger on that battery, it says "1-6cells"
yes it has a built in ballancer.
I dunno if you should get lipos, if you dont know what ur doin u can cause alot of damage.
NJ
INstead of spendin 150 bucks for that why not get the cheaper way?/
like this
http://www3.towerhobbies.com/cgi-bin...?&I=LXMYR6&P=0
like this
This one is even cheaper but doesn't have the built in balancer. http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXKSY1
RI
ORIGINAL: t9dragon
The alligator clips connect your car battery.
can be charged on a car battery
has a built in balancer
can be charged in a outllet
can charge 1-6 lipo batterys and can charge 1-14 NIMH-NICD
and much more but correct me if im wong
RI
what speed should i expect with a mamba max 6900kv motor and esc with this battery? http://www.maxamps.com/proddetail.ph...74-Pack&cat=74
RI
what is the lowest temperture i should ride my truck with the lipo outside? could the lipo die somehow at like 10 degrees?
ORIGINAL: hockey911
