Help with speed
AZ
Help with speed
what brushed motor will make a stampede beat a rustler in a race. the rustler is stock with a titan motor, the pede right now is stock.
dont have enough money for brushless
My Feedback: (325)
RE: pede speed
Adding 1 battery cell or going to a larger pinion or a 15-14 turn motor would do it in a drag race. YOU'd have to go to a 10-12 turn motor to beat it on a track.
My Feedback: (325)
RE: pede speed
http://www2.towerhobbies.com/cgi-bin...C3305&C=CKADTX
Anything with a 14 turn or less would probably drag race the rustler and win. These guys here are all over recommending specific motors, I can't because the only one I used is A Tower hobbies 14 turn quad.
NJ
RE: pede speed
You really can't gear anything lower than a 14t motor in a pede. The rule is that you go 2 teeth below the # of turns on the pinion. There is a rock crawling manufacturor that makes 10 tooth but I'm not sure if that'll fit with a 90t spur.
RE: pede speed
those team orion pro bb motors i hear are quite good. or just up the cell by one. instead of trying to find a 10/90 why not just get like 15/86?
RE: pede speed
ORIGINAL: barefootdan
what u gear for brushless vxl?
there are no turns
there are no turns
brushless motors normally arn't reffered to as turns but more the kv of the motor (the vxl is 3500kv). for the reccord tho, the velineon motor is considered a 10 turn motor.
AZ
RE: Help with speed
so will this motor make the stampede out run a Stock rustler with The titan motor?
http://www3.towerhobbies.com/cgi-bin...1&I=LXJAJ5&P=K
AZ
NJ
RE: Help with speed
not sure about the epic's
trinity makes a nice motor tho
http://www3.towerhobbies.com/cgi-bin...?&I=LXCUP8&P=0
RE: Help with speed
ORIGINAL: brushlessboy16
I have trinity motors with epic endbells....
RE: Help with speed
i have a pede, burnt the stock titan, got a speed gems 15t quad. its way better than the titan, both in accel and top speed. it cost me $33 at lhs.
also, ball bearings will help with speed.
RE: Help with speed
ORIGINAL: RC Freak363
AB, CANADA
RE: Help with speed
I have a speed gem 15t dbl in my XL5 pead geared 16/87. I allso have stock Titan rustler geared 23/86.. the pead definetly will out run the rustler on straight out. On a track the rustler wins 8 /10 times(depends on the corners on the track and the driver)
It's a bit tuff to wheelie geared this high though on 6 cells .But with 7 cell no problem.
SK, BANGLADESH
RE: Help with speed
the motor is important,
but almost as important are what battery packs you're running
a good quality 6 cell pack is faster than a cheap 7 cell pack
get a new motor ($40-60) and a good battery pack ($40-50) and you'll do fine
