official water proofing thread
RI
i have seen a lot of people asking on how to water proof their trucks, so feel free to post pics of you water proofing your trucks for the rain or snow I'm trying to water proof mine, ill post pics later on
RE: official water proofing thread
ORIGINAL: hockey911
thanks
always dreamin
RI
ORIGINAL: Always Dreamin
i would like to water proof my stampede vxl. any suggestions? i have seen ways to make boxes for the esc and stuff but that just looks like too much work. i want something that is easy that can be removed in a snap. also, i want a way to make sure everything is water proof. such as battery, vxl, motor, everything.
thanks
always dreamin
ORIGINAL: hockey911
thanks
always dreamin
sry for the horrible picture, i was using my laptop camera and it shows horrible pics and i didnt wanna soedn $$ sending pics to my e-mail from my phone and having it to take forev.
only one problem. how are you going to mount the esc? about the ziplock, it would work fine but it might be a little big. you might want to try a large baloon. i have a question about those wires. just because the esc is waterproofed, would it hurt if the wires got wet. i mean, they do lead to the esc.
RI
ill tape it down
ORIGINAL: hockey911
im gonna waterproof every connection and electronic ill put the battery in a ziplock and glue the opening
ill tape it down
ill tape it down
RI
don't forget your motor, reciever, and servo. do you have any ideas on how you plan to mount the xl-5?
ORIGINAL: hockey911
ill tape it down
ill tape it down
i found a gerber baby tubberware conatiner heres some pics (1 top runined and wasted trying this lol)
brushed motor can get wet ill post pics of what i did so far
do you have any idea on how you plan to mount it?
Things to note when waterproofing:
1. Battery and (brushed) motor can get wet/run under water
2. If you put your esc in a bag/box/sealed container it will more than likely overheat - you are much better buying a waterproof esc
3. Connections do not need to be waterproofed
4. Reciever just needs put into a balloon to be waterproof
5. Servo can either be put into a balloon with a hole in the top, or you can open it up and seal all the joints inside
anyone ever used testors plastic cement? will puting it on the seams, joints, where wires come out and around heat sink of esc waterproof it?
ON, CANADA
Mold building latex is pretty amazing stuff. You simply paint a thin coat on the cover of your receiver/servo/ESC, let it dry, repeat a few times, and your done. The result is a latex "glove" that fits your piece of electronics perfectly. Don't paint this onto the ESC heatsinks or servo output shafts, the heatsinks are left fine bare and an O ring under the servo saver will keep the servo safe. If you want to remove it you can simply pull it off. You can buy mold builder latex at craft stores like Michaels's.
AB, CANADA
So now it's snowing and I don't have an ESC to go bashing in!![:@]
So I'm thinking about getting another waterproof ESC, what do you guys think....
Mtroniks Viper Truck vs Mtroniks Viper Max vs LRP AI Runner Reverse (not sure if this handles 7 cells??)
Can anyone else suggest any other waterproof esc's that can handle 7 cells?
AB, CANADA
Ai runners are horrible.
Also, quick question....can us bashers use boat ESCs? I need something to get me going in the snow while my mtroniks is getting serviced []
I opened up my Tazer 15T ESC and covered the board in hot glue after rewireing the programming switch to be on the side of the housing. Running an Evader ST with the nice nickname of Submarine(I didn't know the puddle was that deep). Receiver in a balloon with black RTV in the neck followed by a siptie to help seal it. Battery and motor left exposed. Waterproof grease in the drivetrain(so that it won't wash out). Top it all off with a servo that is completely water tight. O-ring on the output shaft, RTV on the seams of the case and were the wire enters the case. It'll drive through a swamp and come out the other side very muddy, but still running as good as when it entered, if only the 1:1 vehicles could be waterproofed so easily.
ORIGINAL: rc monkey
Would silicon work, I saw some at wal-mart....blue siliocon....i think...
AZ
ORIGINAL: RC Freak363
what is wrong with ai runners? i am about to buy one
ORIGINAL: CustomTamiyas4Life
My Feedback: (34)
i didnt get a answer, what is wrong with AI runners
RI
i just ran my truck outside in a cm of snow i water proofed everything and id dint really have to
lol it was awesome! i said i was going outside to run my truck my dad was like no your not your truck will get wet and the electronics will die out
then i showed him what id di to my electronics, he was like wow go have fun
lol it was 5:15 and dark go i got a flashlight and put it on a chair and ran it
donuts! lol with my motor if i go half throtle my motor or tanyy clicks so i ony went half throttle and man was it fun sry, no pics truck was dry when i thgouht
of taking pics and in the driveway the snow coverd from the tracks from my tires
RI
Lucky! Havent gotten any snow yet in ct and i'm like 10 miles away from RI.
