how fast?
RI
how fast?
a vxl motor and esc vs. a mamba max 6900kv motor and esc what speeds should i expect with this battery http://www.maxamps.com/Lipo-10000-111-Pack.htm at 23/86 gearing. (im not shure if i said this right but does 23/86 mean 23 is pinon and 86 is the spur?)
RI
RE: how fast?
ORIGINAL: pede_kid
It'll overheat WAY too fast. Unless your doing really quick speed runs. And running a 3s LiPo on the 6900 isn't the best idea.
RI
RE: how fast?
ORIGINAL: pede_kid
Might be able to get away with it for the 4600 for about 10 minutes or so.
TX
RE: how fast?
come on stop raggen i get 35 min on a 4000 3s and a 5700 this in a t4 geared 20 87 and could get more when i just bash it i gets only 160 on a 2s its way longer like 50 with a 5000 these are good systems stop raggin
NC
RE: how fast?
the 4600 and a 3s lipo will hit about 60,000rpm unloaded. The 5700 will hit 75000. This is alot of rpm, and you need to ru a very small pinion. If you are going that high in voltage, you usually need a very low kv, as this will still produce the desired rpms, have a TON or torque, and have awesome runtimes. Try this:
http://www.hobbycity.com/hobbycity/s...idProduct=4494
My Feedback: (23)
WI
RE: how fast?
ORIGINAL: BackFilp 360
RI
RE: how fast?
ill get the http://www3.towerhobbies.com/cgi-bin...&I=LXKAX3&P=ML so i know if my truck is too hot and ill also get a 18t pinon although i got a 19 that 1 tooth can make a difference
ON, CANADA
RE: how fast?
ORIGINAL: j.m.
I suppose that since the MM systems run at so many RPMs everyone must be incredibly lucky that their systems havn't failed yet............they do have torque you know.
