battery capacity?
IN
battery capacity?
Alright, I did a search and I can't find the answer so i would appreciated some help. Is there something that I can hook up to my battery to tell how many mah is left in it? My charger tells me how many mah it took to peak, but I would like to be able to see at any time how much capacity is left. Thanks
ON, CANADA
RE: battery capacity?
You can only calculate how much went in, how much went out, and by adding or subtracting these how much you have left. A voltmeter will give you a rough idea of how full your battery is.
IN
How can i tell how much ran out? I have a voltmeter, it just reads volts, I want to know how much capacity is left. Is there anything that does this?
WA
You can't tell with just a volt meter... those guys don't know what they are talking about. Even on discharged packs you will be ~7.2v or ~1.2xx per cell.
You need to plug this inline with your system to measure mah to get a ball park figure.
http://www3.towerhobbies.com/cgi-bin...&I=LXLMV0&P=ML
Also you'll lose some energy to internal resistance a.k.a. heat. So the more heat you build the more energy losses (inefficiencies).
IN
I got a killer deal on a Turbo 30 charger that came with NIMH packs and a soldering iron. The charger is not the newest piece of equipment, but it is much better than my stock charger that came with the e-savage. Best of all, I can discharge and cycle my packs with it to get an idea of their health. If I were you, I would get a decent charger/discharger. The previous two products seem to do a whole lot of things including finding mah, but a charger with a discharger might be another option.
ON, CANADA
ORIGINAL: d16z6
