What is a good lipo battery for a brushless T4
CA
Ok well i have a RC10T4 with a mamba max 7700 and i want a good lipo battery.
i was looking at these 2
http://www3.towerhobbies.com/cgi-bin...&I=LXTET3&P=ML
http://www3.towerhobbies.com/cgi-bin...&I=LXTCE1&P=ML
are these 2 any good
what is the difference between a 2s and a 3s lipo which lipo pack above is better
MA
RE: What is a good lipo battery for a brushless T4
The 3S lipo has 3.7 more volts, but you cannot run a 3S lipo with a 7700.
I have not yet heard good things about Venom batteries though. Try the Carbon Edition Orion packs with hard case or some Maxamps packs.
CA
why cant you run a 3s in a 7700
what is a good orion or maxamps battery
im trying not to go over $150
Because the CM36 motors are limited to 65000RPM
7700 x 11.2V = 86240RPM. Way over the design limmits. That is why the 5700 is suposed to be the fastest of the CC motors. 5700 X 11.2 = 63840 RPM.
Personally I favor Hyperion, second choice Max Amps.
B-P-P has an Hyperion 5350 mah 2S for around $93 or a 4250 for about $71.
NC
the flightpower ones are great too.
first one is made specifically for racing:
http://www3.towerhobbies.com/cgi-bin...&I=LXRWF7&P=ML
these are some other good ones:
http://www3.towerhobbies.com/cgi-bin...?&I=LXRWA8&P=7
http://www3.towerhobbies.com/cgi-bin...&I=LXNMF9&P=ML
http://www3.towerhobbies.com/cgi-bin...&I=LXLXR6&P=ML
CA
im thinking about either one of these
but which one should i get
