would a cooling fan help on the mm
RI
I was wondering if a cooling fan on the esc would help the temp. I have been hearing a lot of complaints about overheating with a 7700kv motor. PLEASE HELP. []
VA
RE: would a cooling fan help on the mm
yeah it wont hurt it but my MM does fine with the 7700, and dont forget the 8xl I used to put through it to. Now I run a 10xl on a daily basis and it has never had heat problems.
NV
I run the 25mm novak fans and you can get 4 screws into the heat sink with that one. I also noticed a substantial reduction in temps. With the 7700 if you dont gear it way way down it does get hot especially if you are using it in a truck.
