lipo cut off volts
lipo cut off volts
i have the mamba max and i have a 2s2p max amps 6000 battery, trying to figure out what i could set my cut off volt at ?it offers a 5 and 6 and 9 and 12.....im thinking around 5 or 6 ...one thing i notice is i have it set on auto right now and the past 3 times ive charged it it want hold but 3000 mah and its 6000 mah so i think its cutting it off way to early volt
ON, CANADA
RE: lipo cut off volts
If your going to use the pre made cut off points use the 6V but understand your pushing the battery to its limit. I swear when i had the max that you could make custom cut off points. You don't want to go below 3V per cell.
My Feedback: (325)
The higher the load on battery the lower the cut-off can be.
A small battery with high load might pull down to well below 3 volts and still not be depleted and a large battery with small load may be depleted too much with a 3.2 volt cut-off.
Ultimately shoot for a resting voltage of 3.7 per cell.
