brushed question
FL
brushed question
Hi guys,
I am planning on using two http://www3.towerhobbies.com/cgi-bin...0&I=LXJ766&P=K for a project I have. I understand that using brushless should be my goal for this project but I am going to start with the 600 brushed motors for now.
My question is this. Can I use one 60 amp ESC for these motors which are rated at 26-28 amps?
I know that with Car ESC when you have two motors wired in parallel the esc needs to have twice the motor limit, ie. two 19T motors needs to have one ESC with at least a 9 turn limit.
Does the comparison work with the Flight ESC's too in regards to the amp draw from each motor and the limits of the ESC.
Does a 60 amp ESC equal two 30 amp motors?
thanks for taking the time to look over this for me.
