mrc 977 lipo charging
CA
RE: mrc 977 lipo charging
ORIGINAL: guver
If it is a 2S it charges at 2.5 amps and a 3S charges at 3 amps. MAX (fastest) figures.
This would be like saying that you should charge a 6 cell 4200 NIMH pack at a lower amp rate than a 7 cell NIMH pack.
I charge my 3s Flight Power Evo25 2500 pack at 2.5a while I also charge my 6s Flight Power Evo25 2500 packs at 2.5a.
My Feedback: (325)
Normally that's true, and in this instance the 2s has a 2.5 amp max and the 3s has a 3 amp max.
ps I do charge my Nickel packs the opposite or the way you describe. 10 cell 5amps, 8 cell 6 amps, 6 cell 8 amps ,ect. No matter though [X(]
CA
ORIGINAL: guver
ORIGINAL: dirt101
yeah hes right, the 977 has an amp limiter than you never find out about until you have the charger. I still like mine though.
Don't get me wrong, I am not knocking the 977 as a NIMH charger. I love the fact that I can charge sets of 7 cell packs for my E-Maxx at the same time in about 1 hour. I just don't believe that the 977 is your best choice for charging lipo packs.
My Feedback: (325)
My lipo experience with the 977 was the opposite really, but I came to same conclusion as you. It's a great Nickel dual charger, but I do not use it for lipos.
sometimes I don't get my point across very well. [&:]
KS
Actually that is good to charge to only 85% because if you charge lipos to 85% then you can make them last a whole lot longer than 100%.
NY
ORIGINAL: jordan d
hello all i have a mrc 977 can i charge 2 lipos at the same time with this charger it has 2 outputs
ORIGINAL: guver
Yes, set cell count with battery hooked and the display must read "lipo" (push start from the cell number screen)
the lame part of LiPo charging is the low 2.5A rate for 2S packs. as mentioned, it will charge 3S packs at 3A. strange indeed.
i charge my 2S packs with no problems. to balance, i charge each cell individually as a 1S battery every 4-6 cycles. a peaked Lipo cell is 4.2V. my 977 usually stops when the cell voltage is 4.15V to 4.18V. so its not FULLY charged but better safe than sorry.
