Official E-FIRESTORM thread
#1453
RE: Official E-FIRESTORM thread
Ok, I just got these wheels, and I can't get them to fit? HPI Says they are option parts for the E-Firestorm, so what am I missing? LOL I'm sure I'm being a dunce!
http://www.hpieurope.com/piw.php?lang=en&partNo=2197
Cheers!
Cheers!
#1455
They are 12mm hex, but the look like they are more shallow than the wheels on the flux as standard, but if HPI say they are option parts, they mus fit somehow surely? LOL
Cheers!
Cheers!
#1457
ON, CANADA
just shows how some of us are addicted to RC's. I was up till 2am last night throwing my new brushless system in for the e-firestorm. I was making some test runs up and down the street all in -10C weather LOL! Some would ask why i just didn't buy the Firestorm Flux.....my answer is that i like my cars/trucks to have some personal mods. For some reason i can't stand to run things bone stock. So i've got my LRP speedo coupled with a LRP Vector X11 Stock Spec 9.5 turns. The one BIG problem i ran into was that i couldn't get an ideal gearing to fit. The biggest pinion i could fit was a 24t for a gear ratio of 9.4:1 . The manual for my motor suggests 8.0:1 for 2wd/4wd off road and 9.0:1 for trucks. Hopefully HPI will make some different size spur gears for the e-firestorm. One suggestion for the gearing would be to go for a lower turn motor but my speedo can only handle over 8.5t brushless. What do u guys think?
#1458
1 Post
ORIGINAL: Willystylz
#1459
Ok, they're on, seems they actually are not the best slip on fit like the stock wheels, so just needed a smidge of brute force and ignorance. All fitted now
Cheers all!
Cheers all!
#1460
1 Post
ORIGINAL: CAClark
Cheers all!
Cheers all!
#1462
ON, CANADA
ORIGINAL: redfisher1974
I think you will find that 24t pinion is too big and will run way too hot in the summer if you go offroad at all.......I run 19t on my 8.5 havoc and it pulls pretty good.
#1463
After much experimentation, I have done the final install and config on my FS.
I was using the 2S Zippy battery, but when I got my EZRun I discovered it was way undergeared. As an experiment, I put the fan on the BEC and tried one of my 450 heli lipos. I'm getting top speeds in excess of 40 mph now and everything stays cool. So the new zippy 4000 battery is going up for sale and I'm getting more 3S lipos. It's nice to have everything running on one kind of battery.
When I moved the ESC fan over to the internal BEC, the BEC was overloaded. The Spektrum RX started rebooting at 40 mph. I got an external BEC and the internal BEC only runs the ESC fan now. Everything works fine this way.
I'm going to the beach and run this thing up and down the sandbars for a while. I've got three lipos and two chargers for this car now. Nonstop LOL
#1464
1 Post
even though in the lrp manual it says i'm undergeared? A 19t pinion would really make me undergeared for the motor i have it appears..........unless the gearing is much different for this truck (size of tires??)
#1466
1 Post
ORIGINAL: eaterofdog
.. what do you want for the zippy lipo?
#1467
It's the stock pinion. That's why I went to the 3S lipo, to bump up the RPMs. I haven't gotten an speed reading yet, but I know it goes faster than 40. If it is still undergeared, I am going to a taller tire. I really want to install some badlands tires anyway.
I'll let you know when I sell the zip.
#1468
Yeah, they are in the cupboard, but I need to get some bacl wheels now too, as my clear shell arrived today too.... gonna back and white it like the guy posted in this thread (need some masking tape or something first though!
Cheers!
Cheers!
#1469
the wheels look gangster clark! Glad you got them on... I finally got the storm last night! charged up both packs and ran her.... i was quite nervous after reading the posts that say its deathly slow stock but it was a lot better then i expected. im sure that when my sidewinder and other parts come next week ill have a bigger smile. i was definately impressed with this truck, on a side[:@] note..the turning radius sucks, this is limited by the inability to tune the stock radio, swapped my jr stuff over to it and she goes lock to lock now just wanted to share.... have a great weekend all
#1470
1 Post
ORIGINAL: robertbell6
#1471
Most brushless systems suggest you run one or two teeth smaller then the stock pinion......I and alot of people stay with the stock pinion and are ok...That being said the correct way to gear your setup is by temp.....Get a temp sensor and check the motor temp after a full pack and it should be no hotter then 160 to 170F,Keep in mind it will run hotter offroad then onroad etc....So if its runs 170f onroad you know it will overheat offroad...You can get a temp sensor for 25 bucks off of ebay.....But you should have no problems with the temps in -10 weather...
But for now im sticking with the 9.5 LRP system.
#1472
ON, CANADA
hrmmm i've dropped down from a 24t pinion to a 22t and now i'm at a 20t. The thing is doing wheelies from a standstill but obviously lacks the top speed of the 24t pinion. We need some warmth up here so i can see how hot she gets on a normal summer day.
#1474
1 Post
Thought i may as well post a pic of my E-Firestorm setup And yes that's a lowly Tamiya connector...
#1475
You can get like 10 sets of knockoff deans for $10.
