your worst crash or outta controll rc
well my t maxx 2.5 went outta controll full speed across a ovel and nearly hit a lil girl..oh did her daddy nearly stomp me. and ive never realy had a bad crash my, i just found my max stopped in a ditch*probly outta fuel anyway the engine was sorta screwed after that.
IL
RE: your worst crash or outta controll rc
i took my traxxas rustler off a jump and it hit the ground really hard and broke both of the a arms and snapped the front part of my body... i had to replace the a arms so many times since i had it
i have a nito kyosho mad force,big block and a three speed tranny.very fast .well after sitting for a while i took it out for a test run and a twig got stuck in carb spring and the thing took off at full speed never to be seen in one pc again.can't get the parts to re build it which realy stinks
my mate turned on his TT-01 before his transmitter.
This caused it to get interference and launch off the table at full speed and into some guys nuts, needless to say he needed to sit down
AE
Servo saver works wonders!! Before i had mine, my ofna went WOT stright into a curb did about $80 in dammage new shocks, shock tower needless to say another $25 on top of the$80 for the servo saver. since then no more problems!!!!
NY
A few years back I got a brand new Nitro Rustler 2.5 and my grass was slightly wet. Ran it anyway. The throttle servo got stuck wide open and steering went also. Ended up hitting a wall at about 40, and it kept running into the wall, destroying the entire front end, both servos, and melting the entire tranny. So much for my brand new truck
MN
mine was my t-maxx 3.3 I started the motor but forgot to turn on any thing else. It was stuck in full thortle. It hit a tree and flipped over when it was still going full thortle. I broke a top arm and bent a shocks.
MN
and my e-maxx. A screw fell out of the front tie rod. I had no steering. I hit a car going about 30 mph. I broke a skid plate, 2 bulk heads, a axle, and lost a center cvd.
CA
In my Revo i did a back flip and landed perfectly up-side down. That's how i snapped the crank case in half on my O.S. 18TM
CA
I custom built a Funny car to try the drag racing scene. the set up i had didnt have a speed control what it did was a servo moved and flipped a switch that ran the batteries strait to the motor, used a custom made 3000 matched 10 cell to a 7 turn double. I went to test it out infront of my house and the car took off the best i had ever seen, then it happend, the sevo batteries took a crap and i couldnt shut it off, the funny car ran into a neighbors car at about 70+ MPH, When i got over there i noticed that the car had wedged itself under the tire. I had to ask him to move his car so i could get my car out from undernieth his tire, well that car was done and never tried to make another one.
That must suck... Well, my story: I've been careful...worst that happened, my wheel fell off and I slid into a gutter indention on the side of my street, scratched up, but fine.
My Feedback: (8)
CA
I was being stupid. I gave my friend the opportunity to drive my rustler (XL-5/brushed motor) with a lipo in it. Friend took it on a full speed test run (about 35-40) heading directly toward us. He didn't stop in time and it crashed into a bike. It bent the turnbuckles and front knuckles, the suspension arms also snapped. It was a pretty bad crash. But it was my fault and I learned my lesson.
SC
ORIGINAL: savtraxx
Lesson of the story is not to drive rc cars when its getting dark out.
well my worst model failure was my 28cc gas powered airboat.
i didn't extend the antenna on an AM radio and i had no failsafe.
so while in the park (these boats are amfibious) it went WOT right across the park, hit the path and jumped it, into the skate park hit a ramp off to the side and fliped upsidedown, basicly total carnage!!!!
but my worst rc car accident included am radio + wet carpark and som random guys car[]
shaun
shaun
My Feedback: (23)
WI
My friend likes to stand right in the middle of the street while driving his r/c's and well lets just say I hit him at about 45mph with my old brushless rustler. Thank god only the tire clipped him or something seriously bad coulda happened. The rustler wasnt so fortune though... Broken A-arm, camberlink, turnbuckle, cracked rim, shattered bearing.
CO
Post GTB 3.5, pre-Spektrum radio, my buddies XXX-S decided to shoot across the parking lot, slam into the curb and cause carnage. We both got Spektrums the next day. Only $40 worth of damage or so, but it was impressive.
IN
this really isn't crashing or outta control, but i just want to know what people think of my [link=http://www.rcuvideos.com/item/LL3YL99RTD0GLCNH]VIDEO[/link]
IN
oh and all my vids, you just type mlst mlst2 in the search to see them, i ramp off my 2 ft high and 4 ft long aluminum ramp
my worst crash is when i got a new venom fireball on a brand new venom 300 Mah battery and went down my street and crashed into a concreat storm drain which i lost a wheel and a battery in the drain broke the chassis and every thing on the right side
