YAY! got a sidewinder 4600 today!
NY
Well, i was sick of having my Rusty just sit on the workbench and collect dust (broken ESC)...so I went out and got the sidewinder today! I was planning to get the 5700, but the lhs didn't have it, so i got the 4600. not too different, right?
anyways, i need a little help....
I can't get my pinion off to save my life... i don't know if its the wrench ( the lhs said it fit mine, i lost my original.) or the hex thing on the pinion, but i just cant get it to loosen up a bit..probably the wrench.
I need to pick a connector, traxxas hi-current or deans? or any other high-current connectors you recommend?
the original plan was to get an ener-g 4600 7-cell from boom boom batteries, but of course i have to support the lhs, and time is of the essence (i'd like it up and running by the end of the week). The ones that caught my eye is the venom 4200...is it any good? I think there was also a Losi 4600 pack, and a 5000 pack (can't remember the brand), but give me your battery suggestions.
Gearing is another question (and a subject i have little knowledge about) ...I want a very good top speed, but i'd still like to bash off-road (nothing too bad, just grass, dirt, the average-everyday backyard... ) It's a rustler, if that helps.]
thanks in advance!!
thanks in advance!!
RE: YAY! got a sidewinder 4600 today!
probably made the hex in the pinion or wrench round
i would get lipo
since u got the 4600
you wont see much of a speed increase with nimh
go to radioshack
and grab some GP 3300's
good, cheap batts
the venoms are junk.
i would get lipo
go to radioshack
good, cheap batts
NY
i would get lipo
My Feedback: (23)
WI
ORIGINAL: broken rusty
the different between the 5700 and the 4600 is that the 5700 can be run on 2s and the 4600 can be run on 3s
NY
I think those Losi 4600 NiMH's are looking good... i heard somewhere losi used them to test the speed-t? Again, any suggestions for batts...i dont think lipo is in my budget at the moment.
also, i have a Prophet Sport charger, but it has the tamiya connector...when i choose a connector and buy some, can i just solder the new connector onto the end of the charger and cut the old one off?
ORIGINAL: MahnkenVille
I don't have the 4600, i just said it was my original plan but i had kind of changed my mind. And lipo is a little too pricy for me... but would be awesome if i wasn't on a tight budget. unless theres an inexpensive way to go lipo???
i would get lipo
hobbycity.com
pretty cheap lipos
then theres a venom balancer
for 30 bucks ,,, works great for me
Stay away from venoms. They overheat like crazy. Mine outstretched the shrinkwrap, tearing holes at the area of the hump of my 7 cell. They also lose punch after time, but I didn't see too much of a change in run times.
Minimum for nimh: gp 3300's (radioshack USED to carry them, but now they use generic cells [&o] )
Maximum for nimh: ener-g's, the best nimh ya can get.
NY
did you get the 4600 or the 5700....
im not so sure the ener-g's are the best out
they just came out
need to be more proven
who noes how long they last
i think that elite 4500 and IB 4200 are best
lol ya i thot u meant 4600KV not 4600 mah
hope it runs good!
they just came out
hope it runs good!
NY
thanks, and yeah i'm not sure i want the ener-g's even though i've heard praise of them. See, i have a party to go to on saturday and my friend is really into my RC and i was all like "yeah, i'll have it running by saturday i hope so we have something to do at the party..and it'll be brushless!" and i hear Boom Boom Batteries takes awhile to ship. Maybe after they've been proven a little longer (and the price drops lol!) but i'll ask my lhs if they like those Losi 4600's..or see if they have the ones you recommended.
think my 2400mah nicads will handle it? lmao (haha obviously i'm not serious, but think i'll get at least a few mins runtime off them? maybe if i ran them in parallel..hmm...)
MD
radio snackers should get ya through the weekend not to cut on any battery's or the makers but the venoms imo are low quality 24buck radio snackers are a quick fix and a bit better then venom's would be the nicads you have would probably make the truck sit and stutter mostly but that is just what i have read on nicads but i do have a couple snack batteyr packs and they work good imo hope that helps Peace
NY
thanks, i'll have to head down to radioshack..should make good basher/backup packs
thanks everyone, i'll update when i get the batts. but any connector and gearing ideas?
for connectors
deans for the batt and esc
and bullets for the motor and esc
remember
female on the batt
male on esc
for deans
dont want any shorting out
especially if you get some nice batts =D
try stock gearing
than work your way up
see if your LHS
has a robinson 6 pack pinion gear set
48pitch should be good
low pinion = more accel, less speed, more run time
hi pinion= less accel, more speed, less run time
low spur= less accel, more speed, less run time
hi spur= more accel, less speed, more run time
have fun!
remember
female on the batt
male on esc
for deans
try stock gearing
see if your LHS
have fun!
CA
ORIGINAL: whothefashizle
NY
I believe the sidewinder ESC can be run with the VXL motor... here's a quote from the manual...
"Brushless: Other manufacturers: Motors must have Kv same or lower than ours and the motor must be ran within motor manufacturer's specs."
so i think it would work.
quick questions...theres no mounting bracket or anything for it, should i just use some good double-sided tape and put it over the old ESC's mounting bracket?
And since i'm upgrading the pinion gear anyway, and i really just wanna get this thing mounted at least...can i just pop the old pinion gear off with pliers or something (I think the grub screw is stripped or something, nothing's working to get it out with the hex wrench.)
thanks.
thanks.
ON, CANADA
Hows this 4600 you guys speak of?, I dont run low numbers like that, but this new sidewinder 4600 sounds like it would be a good canidate for my evader?, what do you guys think,
NY
took a look at those lipos just now...they're not too pricy!
i kinda liked this one: [link]http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=4131[/link]
and this charger: [link]http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=3823[/link]
will good Nimh get me up to 45, though? (geared properly) cause it may take me a little bit before i can afford the lipo stuff and i need a speed fix before i get that much $$ again haha.
NY
ON, CANADA
Maybe, 45mph is preety quick and nimh's are a waste of time sooo i donno man, id get a good Lipo charger and good lipo battery, like a DTX ICE charger and a nice 2s lipo and you'll be set
and alright great!
and alright great!
KS
Double sided tape is fine for mounting the ESC. I recommend going to an auto parts store and getting the 3M brand double sided tape that is used for mounting moldings, bug deflectors, etc. It is used OEM by automotive manufacturers for many badges, and holds up VERY well. It's about $5 for 5 feet.
As far as gear selection goes, go to http://www.castlecreations.com/suppo...ring_chart.pdf , it is the breakdown of recommended gearing for motor/ESC/battery combinations.
If you get a good 7 cell and get in broken in.... I hope you enjoy wheelies. I've got a Sidewinder/5700 in my Rustler and it is a fun little machine.
