Lee's Tamiya DF-01 build thread
#78
RE: Lee's Tamiya DF-01 build thread
well, better late than never, so they say, so the Cayenne finally got a run today, as you can see the private car park i visited has a few varied surfaces, light pebbles, large pebbles and grass.. almost perfect terrain for the Cayenne.
#79
the Cayenne is a very fun vehicle, taking some big hits and very rarely rolling, i also feel its more capable than my TA-02 and CC-01, having slightly more clearance than the TA-02, yet not rolling at every corner like the CC-01, i did suffer some cogging, but that seemed to go after a few passes, unlike the previous two cars i mentioned, this will not be getting sold [8D]
however i did have a couple of issues.. the right front dog bone kept popping out, so i used an o-ring in the outdrive, and as with the CC-01, i lost one of the screws holding the bottom of the damper in..
i also switched the steering links to the top of the front uprights as i felt the links were at an awkward angle (even with the suspension un-compressed) another benefit is the links are higher off the ground and a bit more protected.
i shot a video, but with a lack of options to mount the camera off the ground, its hard to get a good perspective on the speed of this vehicle, i would guess about 20 mph, but bear in mind its on the second smallest pinion (the motor/ESC weren't even warm..) and i do have the speed tuned gear-set if i feel the need... [>:]
if the tracking seems a bit random, the two right tyres kept coming unglued.. [X(]
http://www.youtube.com/watch?v=lOxyZ5gCPlM
#80
ORIGINAL: The Collector1
Heres a couple of pics of my Manta ray to show you the center shaft, I also used a Yeah Racing motor mount
if they are made from the same clear plastic as my M-03R ones were, be careful, they break very easily
#82
Yeah, but you are not supposed to crash an on-road car.... (joke)
ORIGINAL: rcluke
#83
took the Cayenne out again today and noticed that two of my stick packs only seem to last a few minutes and they are 3600 and 4200... fingers crossed its because they have not seen use in a while..
had a few crazy flips/crashes but the Cayenne shrugged them off, until i noticed a wheel was badly buckled (which would be a pain as the rims are quite pricey and you gotta factor in a tyre as well..) luckily it was only the axle!
better order aome more spares.. just in case..
#86
get one man! the only thing thats annoying is that spare bodies are near impossible to find, as its quite a rare chassis (only a handful of models were made on the DF-01 platform) and of them, only the Cayenne is recent.
decided to switch the step screw/washer setup for the ball connector on the lower shocks mounts, which eliminates any 'slop' and should stop me losing step screws as they work themselves loose... [8D]
#87
stripped the Cayenne completely today, it was caked in mud and needed a good wash!
all the metal parts are soaking in WD-40 and all the gears/shock parts are degreasing..
i will make a couple of changes to it when its rebuilt, the Mamba Sidewinder ESC will go in a sealed Futaba plastic servo box, and the diffs are being switched to bevel units.
#89
ORIGINAL: Lunchboxer
It has ball diffs right now??
#90
at last! we finally have some snow (only about an inch, but that is enough for some fun!)
i had immense fun driving this in the snow, enjoy the vids..
http://www.youtube.com/watch?v=zExOwSCW9EQ
http://www.youtube.com/watch?v=WAMDK-WNuLo
#91
Nice man! Do you have the rear diff locked? Or?
It seems to oversteer quite a bit (fun!), more so than my T-Egg in the snow.. maybe it is because you are generating more speed.. (my T-Egg = silvercan) Or maybe it is the tires...
#93
I just bought a DF-01 and am looking at getting a Tamiya BZ motor for it. It says that you should have a gear ratio between 9:1 and 11:1. I think I read somewhere that the gear raio in the DF-01 is 11.27:1. Is this right, and if so, is that ok?
If not, what do I need to get to make it ok?
Hey guys, so I thought I'd give you an update on my DF-01. I now have a BZ motor and No limit ESC. Just ordered some bearings. I made a fan mount and put it in the DF-01, it works very well. I just bought some new wheels and tyres. They are 3Racing (WH-15/18) intended for a Kyosho ZX-5 or DF-03, but they fit perfectly on the DF-01 (a tiny amount of body modification had to be done). They are a bigger diameter wheel and I am really happy with them, there is a lot more ground clearance and obstacles that the car used to get caught on, it glides straight over now. The only problem is it rolls a bit now, but thats not a real big problem.
Here's some pics of the wheels, the new fan and a Skid/Protective plate that i put underneath the chassis to give the motor a bit more protection.
#95
found an awesome place to off road...
it doesnt take any prisoners though! as you can the the dogbone is bent and twisted!
enjoy the vids..
http://www.youtube.com/watch?v=GxjtPO9jScQ
http://www.youtube.com/watch?v=Ok92_9f9hHY
enjoy the vids..
#99
haha, well i the dogbone came out out a few times, so i just gunned it in reverse and it popped back in!
ive since fixed it with an o-ring in the outdrive..
