tamiya m-03 rally
IL
RE: tamiya m-03 rally
ORIGINAL: supercubfanatic
What can and should i put in a tamiya rover mini m-03 chasis kit that will allow the mini to rally.
NY
I'm deciding to build it at 450 dollars, buy a second model plane at 600 dollars or buy a heli at 200 dollars.I'm a bit short of cash because I'm saving up for the new blackberry bold when it comes out and i'm only in high school so i barely have an income.What specific parts shoulkd I put in the m-03
IL
My mini has: Tamiya cva oil shocks, home made skid plates(made out of scraps of steel and plastic), Futaba 330 esc, 21t trinity street spec motor. Home made shock boots out of balloons, Toyota Tacoma body from old Nikko truck, ball bearings(of course).
Mods:replaced rod ends(on bottom of shocks) with longer traxxas ones to help lift it. Tl01 arms and drive shafts widen it and soften the suspension.Steering rods replaced with spare rear traxxas sledgehammer tie rods.
IL
Also, when you get bearings for it(if you get it)you'll want at least metal shielded ones(rubber shielded ones would be best). Don't get Duratrax's teflon shielded ones. They may be cheaper, but they don't work well for vehicle that will be driving on dirt or dusty places. I drove my m03 in the dirt with those and they won't stop making a grinding noise (and feel) no matter how many times I clean them.
