What to get? Sidewinder or Mamba Max.
Tomorrow Im going to the LHS to get a brushless system, and Im deciding which one to get. I can afford the MM, but I dont know if I need it.
I have a Losi Desert Truck and I want more speed for when I go to the sand dunes, but Im not sure ho wfast I will go with the MM and the SW with my current setup.
I am just running a 4200NiMH with my DT so Im not sure if the MM make a big difference over the SW with a 4200 NiMH.
What would you recommend I do?
I want to eventually get a LiPo but Im not sure when that will be.
How much faster will the SW or MM make my DT?
CA
RE: What to get? Sidewinder or Mamba Max.
Well Chris_RC told me that the Sidewinder has 66% power of a Mamba Max, so if you want the power, get the Mamba, If you will go Lipo, the get the 5700, that will make your 4200mah, (7 cell?) Which cell Lipo do you want to get? if you will only go 2c, get the 7700kv, that is the most power, but the lowest voltage youy can put in it, so you need to figue which works for you, if some reasom ya wanna go slow, get a Sidewinder 5700kv, if ya wanna go fast and gonna go 3c lipo, Mamba 5700, if you wanna go fast without payin the pric of expensive lipo, get the 7700, if you can control it, if ya cant, then get the 6900
OH
ORIGINAL: clamber
Its a 6 cell DTX 4200. And If I get a Lipo it will be a 2s.
Because of the increased power requirements of the 6900 and 7700 kv motors, they are only available with the Mamba Max.
However, the Mamba Max does have the built in USB port for programing. The Sidewinder requires the Castle Link in order to program certain settings. You can program the main things without it, but if you have the Castle Link you can program all the same things on the Sidewinder that you can on the Mamba Max (again, according to Castle Creations).
CA
So if you get the Sidewinder 4600 and plug in the castle link it will have the asme power as the 4600 Mamba Max that comes with the castle link?
CA
What is the speed/power difference between the SW and MM? NONE! ESCs don't make power, motors do. The more powerful motor you choose, the more power you'll have. The only thing you need to worry about with the ESC is that it can handle the current demand of the motor you choose. If the SW can handle it, the MM will not be a faster setup.
OH
ORIGINAL: Chris_RC
The Mamba Max is capable of handling higher amperages than the Sidewinder. But if the motor you are using doesn't draw any more than the Sidewinder can handle, there is no need for the Mamba Max. I called Castle Creations just to see what they had to say about it. I said I was looking at the 5700 motor and they said that if I wasn't planning on using a 3 cell Li-Po there would be no benifit from the Mamba Max. With the 4600 motor you can even use a 3 cell with the Sidewinder. It simply wouldn't have the USB built in.
With the Castle Link you can program all the same settings on the Sidewinder that you can with the Mamba Max. This much I know because I know someone with both ESCs.
IL
Lets keep it simple
no more than 2s=SW
going 3s=MM
Right?
The SW is basicly A lower voltage handling version of the MM? Minus the castle link being included
no more than 2s=SW
going 3s=MM
Right?
Ahh, so the only benefit of the MM is going to come if youre using a 3s. And in that case you will ha a lot of power. But for me just using a NiMH batt and maybe a 2s later on then the SW is perfect right?
Now comes the question of what to get. 4600 or 5700? Which one will give me the most power with my NiMH?
According to this it says that the MM is more powerful if using a 6cell nimh.
http://www.castlecreations.com/suppo...ring_chart.pdf
OH
ORIGINAL: clamber
OH
ORIGINAL: Mufasa_719
Lets keep it simple
no more than 2s=SW
going 3s=MM
Right?
Lets keep it simple
no more than 2s=SW
going 3s=MM
Right?
I meant that the 7700 is 10mph faster than the 5700.
Should I just get the 7700? And then when I upgrade to a 2s the 7700 will work fine with it right?
Is there any downside to having a 7700?
CA
Why not just get a 3s lipo in the near future? If your going all out with a MM 7700, then do it right.
From what I remember, the 5700 with give you some more punch off the line over the 7700. The 7700 will give you higher top end, if you can control it on a light truck like the Losi. I was looking into this stuff for my buddy as well. And heres another thing I heard. With a 6 cell Nimh, your going to get 7-10 minutes ride time, if even that. And Lipos are pricey as well. So after all this research, my buddy ditched the brushless scene cause he didnt want to pay close to 400 bucks and just got a nitro buggy.
Damn, I dont know what to do now. I guess Ill just get whatever and just upgrade to a lipo later like I planned.
Any other comments anyone?
Hi,
I just purchased an e-Firestorm for my 5 year old son. I figured since all his cheaper RC cars broke down it was just a good idea to purchase a single more expensive car that can get replacement parts. The thing is, I love this car
So I started reading on how to upgrade the car to brushless but I´m a confused. Is there a FAQ somewhere that explains all these terms? LiPO, 2s, 3s etc? I also have the following questions.
If I wanted to upgrade to brushless but were thinking more bang for the buck and runtime, ease of use than maximum performance, what should I get?
What is the difference between 2s and 3s?
What else do I need to purchase if I go for a brushless Combo (ESC and Motor)? Connectors as far as I can tell, anything else?
What do I need to change (gearing, spurs and terms I get lost in)?
Can I use the e-Firestorm with brushless to drift (with approriate tires)?
Thanks in advance for your assistance.
Rgds,
Caaine
Rgds,
Caaine
CA
a MAmba 5700 or a Sidewinder 5700,and look, just gear it down by what you can tell on the first few runs, every minute, check the motor and ESC temperature to see if they are really hot for what you are doin, if so just gear it down, I dont know about the Tires, and you have to get connectors for the Battery pack on the BL system. I hope that answered some ques, and look, when gearing down, you gear the pinion down, and the spur up!
