ESC Questions
ESC Questions
I have a evader st with a 12T brushed BB motor and a 7 cell DTX 4200 battery and i also run a few low power 6 cells. i was wondering what a good speed control would be for this combo for around 100 bucks or less
RE: ESC Questions
you could get a brushless sidewinder motor system.no maintanence ,better everything.their about 130 dollars.i have the 5700kv one and im very satisfied.brushed is too much work.if i were u i would get the sidewinder and not worry about it.
AZ
RE: ESC Questions
hey i have the same setup almost i have an evader st with a 12t dbl flash motor and a 7 cell 3600 batterie but im only using the 12t duratrax esc. deffineatly don't get it for your set up. myn will over heat if i run it to hard. on only use it for 4 min races. sidwinder by mamba would be good
