Question for Traxxas owners (front tie bar Rustler, Stampede, Slash)
Well, on the older xl-5 models, they came with some pins that had a screw on the end. with the slash and the vxl models, now it comes with e-clips and suspension pins along with a tie bar. i upgraded to this setup, and i was wondering if there was a better way. i always bend the suspension pins, i never bent my old pins with the phillips head. but then i will lose the tie bar. what should i do?
RE: Question for Traxxas owners (front tie bar Rustler, Stampede, Slash)
your talking about the fiberglass(?) bar that goes infront of the suspention arms? if so, yes you can use the threaded pins from older models, but you have take the bar off, I haven't had any problems in my brushless slash.
ORIGINAL: zjwhitrock
You're gonna bend those hinge pins no matter what you do. Just keep spares on hand and check them after each run.
We talkin king pin or the pins that hold the a-arms on? If you're talkin about the one that goes through the castor block, then get aluminum caster blocks, no more bent pins. If it's the a-arm pins, I don't know then, maybe get aluminum a-arms? Then you'll have a really tough time if you do bend one.
I don't think aluminum A arms would help without an aluminum bulkhead as well. But then what happens when you bend the A arm?
I know its a noob question but i thought its better to ask NOW then damage taking them out lol
i use screw pins and the tie bar at the same time.
it isnt the best idea so i'm upgrading to titanium hinge pin kits
ORIGINAL: TIGER76
Noticed that too ive just my rpm front arms today and was wondering whats the best way to take this pins out with the e-clips on?
An update, I just installed the old XL-5 straight pins with phillips head screws. They work great, no bending, and I don't miss the tie bar one bit!
Sweet thanks for the info bro
I can get on with installing those arms now
