short circuited lipo battery?
alright, so i was putting traxxas connectors on my lipo battery and for a second or split second the red and black wire touched. I don't know if it was long enough to damage the battery. what do you say? When I fully charged it, it peaked at 8.415 volts. Is that normal for a 2s lipo?
RE: short circuited lipo battery?
lipo's puff if you treat them badly for about 1-2 mins.
and usually a shorting is no problem as long as you fix it within a few seconds.
all the shortings ive had were self cured by the battery supplying enough amps to melt the solder on the plugs and stop the short
that lipo will be fine
ORIGINAL: ChuckDeez
thanks, when does the lipo puff? do they puff out of no where even though they were taken care of?
CA
ORIGINAL: t9dragon
Lipos will puff from damage incured during accidents while driving or by over-charging or by running them below the recommend cutoff voltage.
ORIGINAL: ChuckDeez
