rustler LVC problems
i just bought a rustler vxl yesterday, and it runs nimh well. i have 5 2s lipos and whenever i try to run them the low voltage cutoff comes on after 20-30 seconds or so. the batts are 3200s. i measured the voltage and they read 8.x volts. they run fine with the lvc off. do i have to set the vxl speedo to run 2s vs 3s? i believe that the speedo thinks that theres supposed to be a 3s in there because they do read a little more voltage. Any ideas? Thanks
RE: rustler LVC problems
the packs are 20c.
update: i just bought an external liposhield and hooked it up and it doesnt work at all, the vxl goes from red to green whenever i hook it up like it has lost signal... any help?
i bought this
http://dimensionengineering.com/liposhield.htm
i bought this
