Thunder Tiger Sparrowhawk XT
#51
MO
RE: Thunder Tiger Sparrowhawk XT
I'm still waiting on my shocks for my Sparrowhawk from ACE hobby. I've been waiting since 5-11. First they just sent shock bodies that didn't do me any good since I had to send my bad shocks in first. Very iratating. My son has given me a sidewinder 4600 kv for Fathers Day (early) that I want to put in the truck if I ever get it going again. It might just have to go in my Slash for now.
#52
Amain Hobbies started selling XT and XB. You might want to check on spares with them. I am happy with the buggy XB. Still not figured out the reverse issue. Who needs brakes......
Planning a brushless system soon
#53
CT
I'm also interested in this truck. Thanks moebigslee for all the input. I'm a bit wary of purchasing only because it's TT and parts support seems to be an issue right now. I would also be putting a brushless system in it if I purchased. Has anyone run nimh with a brushless system installed in this truck? I'm not a big fan of lipos so I would be running 6 or 7 cell nimh. Thanks
#54
I have the buggy. My ESC got busted in 3 months after a quick run. I replaced with stock ESC, works well now. Quite slow with brushed setup. But ok for the price. Amain should carry most spares and they are similar to the sparrowhawk line of onroad cars.
#55
MO
I finally received my shocks from Ace Hobby after waiting since may 11th. Will try to build them tonight after work so I can drive it again this weekend. Ace Hobbys customer service IMO was terrible. Parts were available they just wouldn't send them or answer emails or phone calls. I'm going to run it a few more times with the stock motor then put my brushless motor in it.
#56
CT
I haven't seen the parts on amain yet. Maybe they have them they just haven't updated their website. I hope they will carry the upgrades aswell. Seems like the truck could use them in a few key places. Keep us updated. I'm personally going to wait I think until amain or someone else starts carrying parts for it.
#57
CT
Did you get your brushless setup installed yet kshoopman? How's it holding up to brushless power? Any trouble spots/weak points on the truck? keep us updated.
#59
CT
I talked to amain yesterday. They are hoping to have parts in stock by the end of the month. Hopefully that's the case. They've been saying "soon" for awhile now.
#60
I replaced the ESC on my Buggy XB after only 3 months of driving. Reverse died first and then functions got totally screwed up. Heard the stock ESC die fast. Cheap replacement though. Indian equal of $50. Stock motor available at Indian equal of $13.
#61
MO
jediguru, I ran the truck this weekend with the stock motor still. I guess I'll get a few more runs on it before I replace it with the brushless system. The only problem I've had is with the shocks blowing the bottom cap off, I guess due to over filling. Overall it seems to be a very durable truck,just wish I could get more power to the front wheels. I've ordered some m3 step pin tires to see if I can get more traction.
#62
what happend with the traction on the front wheels on this car? its a problem of setup or it is a problem of the car. I want to get one but things like this dont help anything cause i dont want another crappy 2wd as my sc10, t4 or efirestomr
#63
MO
If you hold the truck in the air the front wheels spin just fine on throttle but if I set the front tires on the ground they won't spin,just like a 2wd truck. I'm going to dremel a flat spot on the shafts that the drive cups attach to with the set screw as advised by moebigslee. I don't know what kind of traction he is getting with his front wheels.
#64
I'm tninking of selling my Slash and getting the XT. Anyone running serious brushless power through the truck? How does the drivetrain hold up?
#65
MI
ORIGINAL: kshoopman
#66
Thanks for the informative post. I plan on running a Mamba ESC with VXL motor on 3S lipo. The Sparrowhawk will purely be a basher, as I already have an 8ight-E buggy for track use. I think I may just order the XT pretty soon.
#67
Wow this seems like a bad@$$ little truck. I was thinking bout getting a T4 evntually but I like the idea of 4wd a little better. Maybe it's only cuz i used the smoke cigs; but the stock red wing looks like a pack of marlboro reds LOL
#69
MO
Been on vacation for a week. I finally got my 4wd working correctly. Still running my stock motor,but this truck is a blast to drive. Switched out my tires with steppins and they hook up really well. I'll probaly hold off a while before putting in my brushless motor,mainly since my track is pretty small. Still no pictures or video to post.
#72
MO
ORIGINAL: kshoopman
MTboy, I measured the battery compartment and it is L160 x W50 x H30 (mm's). Hope that helps.
#74
MO
Just a thought for anybody wanting to use lipo's in this truck. I wanted to see if my son's 5200 lipo would fit and i really had to squeeze it in the compartment. The problem I see is that the hold down strap won't fit with the way the wires come up thru the top of the battery. I don't use lipo ( still going with old school nicd & nimhs ) so I don't know if you can really bend those wires drastically.
I'm not sure if moebigslee is using lipo with his brushless system or not, but maybe he can chime in on the subject.
#75
Sorry for all the questions... but does anyone know if the stock ESC has a reverse lockout feature for racingt? Trying to use it in another application.
