PLEASE HELP! PROBLEM WITH RUSTLER VXL!!!
i am a begginer at rc. and i have been getting this problem with my rustler vxl, where after driving it for about 5 minutes it will start going in reverse at full speed without me touching the throttle and wont stop. i checked the throttle trim and it is at 0.after i unpluging it and then pluging it back in, the throttle doesent work at all and then after about 10-15 mins of leaving it aloneturned off.the throttle works again. this same problem happened to me twice. if i did not give enough information just say so.
please help!
please help!
AZ
RE: PLEASE HELP! PROBLEM WITH RUSTLER VXL!!!
Ya you're probably getting radio interference. Reprogram the radio to you car. If that doesn't work try a different set of crystals. Or if you have the money, get a 2.4GHz radio system. But I recommend you try my first two solutions first.
