Battery And Esc Problem
I need help i might have a battery and esc problem i think my esc is using up my batts way tooo fast.i have 2 1500 battts and my car runs out in like 5 min.Is my prob just the batts have low mah. or is the esc is putting tooo much jiuce.
THX,
Reece
THX,
Reece
I have a trinity monster pro stock moter and and a 78 tooth gear but i dont know about the pinion its robinsons gear but dont know what tooth it is the guy at hobby people helped me out it might be a good pinion for the rpm for the motor and also the motor is stock. I have a team losi xxx kinwald edition buggy.
oh yeah the motor get REAL REAL HOTT this afternon when i drove it it was smoking i got kinda worried and didnt drive it after that i have a activator sport charger and a black widow i drive my car on grass bud im gonna race it.
If there sanything I have learned, it is that you should NEVER let your motor get even CLOSE to that hot. You will wreck your electronics quick.
IF your motor is getting really hot then you need to get smaller pinion gears. Try some that are 4 to 5 teeth smaller and get a few different sizes cause the different motors and different track conditions need different gearing. If your motor was smoking then you may need to have it rebuilt. You should always check your motor after a run to see if it is too hot. This will help you with figuring the gears you need to run. Good luck and let us know how things are going.
Ryan
Ryan
FL
it could be that you are drawing the power to quickly with ur esc and motor combination. 1500's never run long enough if you are doing alot of bashing. they are made for a slower more beginner car. Id move up to 2400s or a radioshack 3000. 36 bux and they are just awesome bashers, lasts my in my tc3 for about 12 minutes(unless false peaked)
Make sure you get som smaller pinions. That will make your run times longer and allow your motor to run cooler cause it wont have to work so hard. Once you get your gearing set then you are ready for bigger batteries. A bigger with the wrong gearing will definetly fry your motor. Have fun and always check the motor temp when done running. That is a real good test to find out if something is wrong.
