View Poll Results: A poll
Other: Please state reason
0
0%
Voters: 49. You may not vote on this poll
Hard case or soft case Lipos?
RE: Hard case or soft case Lipos?
ORIGINAL: Chris_RC
Your $30 Zippy wont give the performance as the same C battery from say Orion, SMC, Thunder Power, Checkpoint or Reedy. Their batteries are more expensive because-
more r&d
better customer support
US brands
and they sponsor their drivers
It isnt like they are only paying $15 for the lipo and pocketing $100.
And I dont care about MaxAmps, they are the exception to the rule. Go by an actual manafacter, not a company that is based (and still operates) in a 2 car garage like MaxAmps.
ORIGINAL: monsterbombs
soft case. cheap,powerful and safe providing you follow the rules. any
lipo will fail if you ecceed the boundaries with it. i bought two 3s lipo (2450mah) 30c
softcases (about $70). i run them in a vxl/mamba setup without reliability or heat issues. ever.
now i decided to be silly and hook up a 6900kv mamba motor. needless to say she
went boom boom. i went to the lhs and the batteries there were simmilar in weight
to a small dog. [X(] nearly $300 and if you do something stupid it will let go. like
any battery. my cheap softcases do the samething, for a fifth of the cost in some cases.
just because they are expensive doesnt mean they dont fail. maxamps proved this.
my hong kong batterys do the job and as long as i keep within the parametres i
should get a couple of hundred cycles. for about 30 dollars
oh and i have a hard pack a kong power 4600 2s. it had its day. flew about 200metres
down the road, had a cracked case and lived. that battery is hardcore. the cells could be
puffed or damaged and i wouldnt know. i dont use that much now. oh and that was about $170 [:'(]
more r&d
US brands
second off i didnt say they were zippy's
and how would you know they dont give the
performance like other brands if you dont even
know what ones im using. i think you also might
be surprised that some of the "brand" batterys are
coming from the same place.
you even said it. your paying for customer service,
a " US brand" and there sponsers. no wonder the batterys
are through the roof. i know there are quality batterys
like thunderpower and my kong power is up there but
how many of the "us brands" are actually manufacturing there own
cells in house. not many i wouldnt think.
how many of the ''us brands'' are actually manufacturing there own
You might have some cases where the cells are built overseas and then assembled on-demand here in the US, but that is pretty much it. When you hear of GM or LG or someone like that building a new plant in the US, that is actually just an assembly plant. They are taking cells built in China and putting them into a "value-add" assembly locally.
http://www.atp.nist.gov/eao/wp05-01/contents.htm
This report was written in 2005. Then Kokam (Korean) was one of the major manufacturers for Lithium-Ion-Polymer and now they are not so much of a factor as they once were. There are some attempts to build large-scale factories here in the US, for instance:
http://www.boston-power.com/boston-p...anufactur.html
but even those acknowledge:
"Currently, nearly all lithium-ion batteries in the world are manufactured in Asia."
http://en.wikipedia.org/wiki/Lithium...sphate_battery
http://en.wikipedia.org/wiki/BYD_Company
etc.
as of now i only have nitro so i wont vote but if i get an electric for racing it will be undoubtedly hard case. even if you only run in marshlands you can still puncture a soft pack. the only time i would recamend a soft pack is if that person was racing and needed to shave every ounce they could.
FL
ORIGINAL: Chris_RC
more r&d
US brands
more r&d
US brands
My point is that a name brand doesn't mean Horse Squeeze. They all buy the cells from just a few manufactures, so you are likely paying 4 TIMES what we are, for exactly the same thing. But if that makes you "Feel" better, then by all means, go for it.
i have ten or so total soft lipo packs and want to bash with them. what should i pad the battery trays on my savage flux with to make sure they don't shake?
ORIGINAL: FoamyVictim
WRONG. The C rating on my Zippy packs is spot on. In fact, my 20C 4S 4900 Zippy performs almost exactly the same as my 25C 4S 5000 Losi pack. In fact, I've used them about the same amount of times(was using both in my 8ight E) Guess what? The Losi pack puffed two cells, the Zippy is still going.
My point is that a name brand doesn't mean Horse Squeeze. They all buy the cells from just a few manufactures, so you are likely paying 4 TIMES what we are, for exactly the same thing. But if that makes you ''Feel'' better, then by all means, go for it.
If you take something like the Thunderpower 40C packs, or some of the newer Orions, there are no real equivelents when it comes to the cheaper cells. But, you're still paying more than twice the price for a teeny bit of extra performance.
I don't disagree with the rest of your post, but people have a tendency to get pigeonholed into a simple this/that type argument when in reality things are a bit more complex. There's a lot of expensive brands doing the OEM/re-label/re-sell thing but there's also a few that really do deliver something more for the cost... whether you need that extra little bit of performance (and maybe reliability, but that's debatable) is up to you to decide. Racers typically want every last little bit of performance they can get, and cost is often beside the point.
#31
FL
My point is that even if a "Big Brand Name" is on the label, it doesn't mean you're getting a good product. I generally take what I read online with a grain of salt, and use mine and my local racer's personal experience to make the final call.
#32
good points.
i will tell you right now my kong power lipo is made in taiwan
if there is any "us brand" that even comes close to it i would like to know.
that will decimate nearly any other lipo out there. truthfully.
it did cost a bit more though but yeh.
#33
#34
WV
Thanks for everyone's input and opinions. There is a good bit of information for me and hopefully others to make a decision on which type of Lipo to use.
I didn't mean for the topic to get heated or for it to sound like a topic that a troll would start. My original intention was to gather as much info as possible so I and others could make a safe and informed decision. I hope there are no hard feelings.
You have even got me thinking about using a soft lipo and making some kind of tray to fit over the Slash's battery tray to protect the lipo. I could possibly use some sort of U channel cut to fit precisely over the battery tray and held in place by the body clip. I'm even contemplating finding a better system than using the included body clip although it would have to be easy to remove in the event of fire. All this is not necessary but it's a couple ideas running around my head thanks to the responses in this thread.
Regards
Regards
#35
FL
ORIGINAL: moron88
Puncture with what?.... are there natives throwing spears at your car? Look, I've said it before, and I'll repeat myself. A decent battery tray provides more than enough protection. These aren't balloons or panty hose, they aren't nearly as fragile as you guys think they are. I've seen soft packs hit the ground at warp 9 in a small foam ducted fan jet. The plane was a total loss, all servos destroyed. All that survived, was the lipo and the receiver.
shock shafts, jagged broken shock towers, screws, body pins, plastics etc, etc. get going fast enough any thing can go through anything.
I hope this debate not only informed people, but let the domestic retailers know why we're bailing on them. They just can't compete with what they are charging for their lipos right now. Sure, there will be hard headed or finicky people that will only order from the States, but that won't last forever. People in this hobby need to think in terms of longevity, IF they want the hobby to last. You can't last if you can't compete, and few people are gonna spend money when they don't have to.
#37
FL
ORIGINAL: overrev
My opinion is use what you want there is no right or wrong. But the poll does show more people use hard case in cars.
#38
CA
FoamyVictim, you will convice me that soft case Zippy lipos are the way to go if you answer a few questions.
Take Kokam cells for example. Orion sells a 3800 30C for $80. Do the chinese places sell Kokam cells with around those specs for $30? Same with SMC, I dont know what cells they have but you can get a 6000 2S with Deans for $80. Can you get those for $50? What I am trying to ask is give me an example of where an expensive racing company and a cheap chinese company gets the same cells.
But, saying they are the same cells from the cheaper to the more expensive batteries is an unproved statement.
#39
FL
I can't prove where the cells come from because I didn't buy, assemble and then sell them at highly inflated prices. I can, however, post a link to the place I get mine from. Will they satisfy you?... you be the judge:
http://www.hobbyking.com/hobbycity/store/uh_index.asp#
As was stated before. The difference between the cheap packs and identically rated expensive packs is virtually undetectable. I've had both(although somebody said the Losi packs are junk anyway) and the difference was so marginal, it couldn't POSSIBLY account for the 300-400% price difference.
As I said before. If you want to blow your money, then By All Means, support the domestic lipo market. I want to race, and often. If I can do it for 20% of the cost...well, Logic steps in and says... YUP! [8D]
#40
My Feedback: (32)
IA
Ijust bougt two 5000mah's 20C Tenergy LIPO (soft packs) and a universal smart charger all for $117 shipped. The lipos were on sale for $40 each. I've never had problems with Tenergy as I've used them for my NIMH batteries as well.
In addition, Ibuy all my batteries and chargers from All-Battery.com.
Awesome place.
Awesome place.
#41
FL
i use both, for some of my projects a hard case is better for safety and durability resons but for my srt and eagle (both racers) i run soft cases mostly for weight and like others say to keep an eye on um, my track does not have a batt rule just a cell count limit, 2s or 6c [respectively] for 1/10th classes and 4s for 1/8th.
#42
IL
I use hard case LiPos, but primarily because they used to be strapped to the side of a custom E-Savage chassis - literally. Not battery tray there. So I thought it would be prudent to go hard case, since I flipped that truck so many times in some rough (but fun!) terrain.
I'd buy a soft case one though, if I was putting it in a battery tray (like most vehicles have).
Couple questions though, since I don't have a soft lipo:
1) If you are a clutz and drop the thing to the ground, or, say, just to your work bench, will it dent?
2) Folks keep saying that with a soft lipo, you're safer since you can see when it's puffing. So what - you guys look under the hood every 2 minutes during a race or bash session to look for puffing? I get the idea (i.e., hard case hides cell puffing) - but realistically, who's checking that soft case during a run, and how often?
#43
FL
i check mine after a race or long bash since im putting the most strain on them then
as far as impact resistance, they can take some abuse its not like if you look at them wrong they dent or anything, ive tossed a pack onto my workbench once, didnt do anything, then again, i ran a soft case on my hpi rs4 mt a few weeks back and after a real nasty tumble i noticed that i bent the pack slightly but after a few race days it straitened up because of the way they are mounted in my srt
